Re: Challeger Covert. windshield frame height dimension.
[Re: Cloned_Cuda]
#1043603
07/31/11 02:06 PM
07/31/11 02:06 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
there probably will not be any specs for that dimension. i have never seen any myself. look at how the windshield, door glass, and how the top fits to the header to determine height. with those parts installed it should be easy to figure it out.
perception is 90% of reality
[Re: Cloned_Cuda]
#1043604
07/31/11 02:22 PM
07/31/11 02:22 PM
Posts: 4,799 ILL
MLR426
ILL
Anyone have a drawing with height dimensions to check the windshield frame, it appears to be low on the drvers side or to high on pass. side. Thanks!!!
are you sure it's not an illusion ? mine appeared high on the driver side when working on it. I believe my deminsion from the rocker to the top corner pinch weld on the bottom of the frame was 53 1/2 I'll try to remember to go back in some e-mails and see if I can find out where I put that measurement. Several people on this board possibly have converts striped out and can measure that demension if they take the time to do it.
logan426
[Re: MLR426]
#1043608
08/03/11 01:50 PM
08/03/11 01:50 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Is convertible windshield the same as hardtop? If so, shouldn't the measurements be the same? If yes to both, I could grab some measurements off a project I am working on. Its a hardtop, well, sort of, until I get the roof skin back on.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1043609
08/03/11 03:11 PM
08/03/11 03:11 PM
Posts: 4,799 ILL
MLR426
ILL
Problem is measuring from the same frame reference point at the frame corner pinch weld to the top of the rockers. Convert would be best. May try from the center of the front floor pan foot well to to the windshield pinch weld to get another measurement point.
logan426
