I had a custom Comp Roller spec'd from Dewayne Porter I ran in a 493 with cnc -1's. Compression was on the mild side at 12:1 or so. I had good Jesel Rockers and valve train..
The engine ran well...
I finally built a real short block with a Indy Maxx block 4.5" stroke crank 4.44 bore for 557 CID. Compression was up there north of 15:1.. I upgraded the induction also with a 4" Toilet Rons setup..
I went ahead and used the Comp Roller from the 493 in the new short block.
Cam was a ground on a 112 LSA .770+ lift and duration was mid to high 270's at .050 lift. I installed it in at a 108 ICL. It ran very well in the new engine.
I had decided that maybe a new cam for this motor might be worth the money. I could afford to go bigger and not worry to much about tq loss down low cause now the weight went from a 3000 lb Dakota to a 2100 lbs race car...
So the new cam had a hair over .800 lift dur was 280 or so at .050 and now on a 113 LSA.
This cam was spec'd by Chuck Millen from best machine...
The car didnt show any improvement, didnt loose any either.... ran within a few numbers either way.
I think if one's in the ball park, there isnt going to be much there.
