School me on AFTER market SMALL Blocks.. #1043070
07/30/11 11:48 AM
07/30/11 11:48 AM
Lake Charles,Louisiana
BILLYJAY Offline OP
BILLYJAY  Offline OP
was thinking about a new project but has been so long since i built anything other than a 340 stock motor.. interested in building a 700-900hp small block.. but probally will use NOS to acheive the last 200-300hp of that.. not sure which after market block is the way to go and a good set of heads to use.. i dfont want to break the bank on this but a decent build and a bullet proof bottom end is a must.. any info will help...
Re: School me on AFTER market SMALL Blocks.. [Re: BILLYJAY] #1043071
07/30/11 11:53 AM
07/30/11 11:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your talking R block stuff... would go 48* siamese
bore
Re: School me on AFTER market SMALL Blocks.. [Re: MR_P_BODY] #1043072
07/30/11 12:16 PM
07/30/11 12:16 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
i notice that they offer a few different deck heights...i am guessing this is to allow for the bigger stroker kits ??? Cam location is not an issue with these small block setups.??? also why the 48*instead of the 59* ??? i notice that indy doesnt have the 360-1 heads on their site anymore.. i use the think those were the best small block heads going.. whats the scoop on a good set of heads.??? thanks...
Re: School me on AFTER market SMALL Blocks.. [Re: BILLYJAY] #1043073
07/30/11 12:23 PM
07/30/11 12:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well you can go with a W-9 head they're pretty cheap
and they use the extra bolts for better clamping of
the head... you might want the taller block... watch
for what crank journal size... theres a few different
sizes
Re: School me on AFTER market SMALL Blocks.. [Re: MR_P_BODY] #1043074
07/30/11 12:33 PM
07/30/11 12:33 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
can you recomend any site where i may beable to see the heads and info on them other than indy.. there is not alot on there to help me with...
Re: School me on AFTER market SMALL Blocks.. [Re: BILLYJAY] #1043075
07/30/11 12:55 PM
07/30/11 12:55 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
I would start with RyanJ's website for his Shady Dell Speed Shop. Some good info on there about the different blocks and heads. http://www.shadydellspeedshop.com/
Re: School me on AFTER market SMALL Blocks.. [Re: Devilbrad] #1043076
07/30/11 01:03 PM
07/30/11 01:03 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
thanks..i had just found that site when you answered me...
Re: School me on AFTER market SMALL Blocks.. [Re: BILLYJAY] #1043077
07/30/11 01:25 PM
07/30/11 01:25 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
if ur interested i know someone with all u need..but 700hp pump gas! would be easy with w 7 8 or 9 cylinder heads ..block's right now are about $2300 they go up an down in price...top end with t&D rockers 2500 for intake heads and rockers
Re: School me on AFTER market SMALL Blocks.. [Re: fishy340] #1043078
07/30/11 03:33 PM
07/30/11 03:33 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
interested in knowing how much HP the 340 blocks can handle.??? there are several to choose from.. 340 resto block and r3 race block and siemese and non...anyone have a chart showing the ratings.??
Re: School me on AFTER market SMALL Blocks.. [Re: BILLYJAY] #1043079
07/30/11 03:45 PM
07/30/11 03:45 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
No one knows, the resto block is an R3 in disguise. 1000hp and up should be easy for these blocks.
Re: School me on AFTER market SMALL Blocks.. [Re: Devilbrad] #1043080
07/30/11 03:58 PM
07/30/11 03:58 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
All the new r3's look like resto blocks. Forget the cheap aspect of it all though, you more than likely will break the bank . for complete, ported W series heads and t&d rockers you are looking at 5K alone (includes buying the heads and NEW rockers). 2500~ish for a block, and 48* roller cam with offset lifters are a ton. Not to mention the custom headers and pistons.
Re: School me on AFTER market SMALL Blocks.. [Re: BILLYJAY] #1043081
07/30/11 04:23 PM
07/30/11 04:23 PM
Delray beach, Florida
P
Performance Only Offline
P
i've got a complete R-3 based combo with 360-1 heads, Harland Sharp rockers, all good parts in the rotating assembly. custom pan, billit (not chinese) valve covers, electric waterpump, etc. etc. if it's something your interested in let me know. it's all new stuff. it's not a not a pump gas motor and we're not "giving" it away, but if your serious it's 700hp n/a capable with the right cam.
machine shop owner and engine builder
Re: School me on AFTER market SMALL Blocks.. [Re: Performance Only] #1043082
07/30/11 04:40 PM
07/30/11 04:40 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
R-3 has a ton of variants. wet sump , dry sump , short deck , tall deck , 48 degree , 59 degree.
The 48 degree is preferred for high r.p.m. use due to better push rod geometry. Siamese blocks will allow a larger bore.
The tall deck will allow you to run a longer stroke and rod without having to run a super tight ring package.
W-9 heads are what I am going with , and they also make a 59 degree version of those that has the valley side head bolt bosses machined away for push rod clearance.
I think the outer head bolt bosses are also cleaned off , and they are clearanced for the pushrods on the sides of the intake ports which limit how much meat you can safely remove when porting.
If I was going with 59 degree , I'd probably look at other options.......mostly due to fewer choices in intake and exhaust.
Re: School me on AFTER market SMALL Blocks.. [Re: tubtar] #1043083
07/30/11 04:42 PM
07/30/11 04:42 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I forgot to mention cam bearings too.........
The best advice I could give is be certain of what you buy and that it will fit your end use.
Some take babbit cam bearings , some are 50 m.m. and some are 60 m.m. rollers.
