Re: School me on AFTER market SMALL Blocks..
[Re: BILLYJAY]
#1043073
07/30/11 12:23 PM
07/30/11 12:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well you can go with a W-9 head they're pretty cheap and they use the extra bolts for better clamping of the head... you might want the taller block... watch for what crank journal size... theres a few different sizes ![](/ubbthreads/images/graemlins/wave.gif)
[Re: BILLYJAY]
#1043075
07/30/11 12:55 PM
07/30/11 12:55 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
can you recomend any site where i may beable to see the heads and info on them other than indy.. there is not alot on there to help me with...
I would start with RyanJ's website for his Shady Dell Speed Shop. Some good info on there about the different blocks and heads. http://www.shadydellspeedshop.com/
[Re: BILLYJAY]
#1043079
07/30/11 03:45 PM
07/30/11 03:45 PM
Devilbrad
Pacifica, CA
interested in knowing how much HP the 340 blocks can handle.??? there are several to choose from.. 340 resto block and r3 race block and siemese and non...anyone have a chart showing the ratings.??
No one knows, the resto block is an R3 in disguise. 1000hp and up should be easy for these blocks.
[Re: Devilbrad]
#1043080
07/30/11 03:58 PM
07/30/11 03:58 PM
Posts: 3,396 Pa
Hot 340
Pa
All the new r3's look like resto blocks. Forget the cheap aspect of it all though, you more than likely will break the bank ![](/ubbthreads/images/graemlins/biggrin.gif) . for complete, ported W series heads and t&d rockers you are looking at 5K alone (includes buying the heads and NEW rockers). 2500~ish for a block, and 48* roller cam with offset lifters are a ton. Not to mention the custom headers and pistons.
[Re: BILLYJAY]
#1043081
07/30/11 04:23 PM
07/30/11 04:23 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i've got a complete R-3 based combo with 360-1 heads, Harland Sharp rockers, all good parts in the rotating assembly. custom pan, billit (not chinese) valve covers, electric waterpump, etc. etc. if it's something your interested in let me know. it's all new stuff. it's not a not a pump gas motor and we're not "giving" it away, but if your serious it's 700hp n/a capable with the right cam.
machine shop owner and engine builder
[Re: Performance Only]
#1043082
07/30/11 04:40 PM
07/30/11 04:40 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
R-3 has a ton of variants. wet sump , dry sump , short deck , tall deck , 48 degree , 59 degree. The 48 degree is preferred for high r.p.m. use due to better push rod geometry. Siamese blocks will allow a larger bore. The tall deck will allow you to run a longer stroke and rod without having to run a super tight ring package. W-9 heads are what I am going with , and they also make a 59 degree version of those that has the valley side head bolt bosses machined away for push rod clearance. I think the outer head bolt bosses are also cleaned off , and they are clearanced for the pushrods on the sides of the intake ports which limit how much meat you can safely remove when porting. If I was going with 59 degree , I'd probably look at other options.......mostly due to fewer choices in intake and exhaust.
[Re: tubtar]
#1043083
07/30/11 04:42 PM
07/30/11 04:42 PM
tubtar
St. Paul , Mn.
I forgot to mention cam bearings too......... ![](/ubbthreads/images/graemlins/laugh2.gif) The best advice I could give is be certain of what you buy and that it will fit your end use. Some take babbit cam bearings , some are 50 m.m. and some are 60 m.m. rollers.
