Does any one have plans for a K-frame & rear axle dolly #1042977
07/30/11 05:32 AM
07/30/11 05:32 AM
Arizona
69rrgrabber Offline OP
Arizona
I decided to go all the way and put my charger on a rotisserie! I was thinking of making a dolly for the K-frame and also one for the rear axle (DANA). I have seen people have thier K-frame loaded up with the motor, tranny and suspension and mount it to their car from underneath and would like to do the same.
Any tips or plans would be most appreciated!
Thanks!
CAC
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Does any one have plans for a K-frame & rear axle dolly [Re: 69rrgrabber] #1042978
07/30/11 05:31 PM
07/30/11 05:31 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Heres one I have that a friend made. I would use swivel casters on all wheels as it makes minor adjustments easier when its under the car.
Re: Does any one have plans for a K-frame & rear axle dolly [Re: NV69B7RR] #1042979
07/30/11 05:32 PM
07/30/11 05:32 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Heres the dimensions. Forgive the quick, crude drawing.
Re: Does any one have plans for a K-frame & rear axle dolly [Re: NV69B7RR] #1042980
07/30/11 05:34 PM
07/30/11 05:34 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Here it is in use. By making the bottle jack sliding/ adjustable in the back it can be used for all types of motor and trans combos. PM me if you need other measurements.
Re: Does any one have plans for a K-frame & rear axle dolly [Re: NV69B7RR] #1042981
07/30/11 05:38 PM
07/30/11 05:38 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
You might try asking this over in the resto section to get some better response.
Re: Does any one have plans for a K-frame & rear axle dolly [Re: 69rrgrabber] #1042982
07/31/11 05:53 PM
07/31/11 05:53 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
If you are in Phx area I can loan you the set up that I already have made up out of an old airport luggage tram.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Does any one have plans for a K-frame & rear axle dolly [Re: AZ_A12_BEE] #1042983
08/16/11 02:55 AM
08/16/11 02:55 AM
Arizona
Arizona
Thanks guys for the pictures, drawings and offers. I'm putting one together this weekend!
Re: Does any one have plans for a K-frame & rear axle dolly [Re: 69rrgrabber] #1042984
08/16/11 07:27 AM
08/16/11 07:27 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Not mine - Farmboys on cuda-challenger.com
Re: Does any one have plans for a K-frame & rear axle dolly [Re: larry4406] #1042985
08/16/11 01:22 PM
08/16/11 01:22 PM
Arizona
Arizona
That is heavy-duty!
