Advantages of the MP 484 and 509 cams ? #1042960
07/30/11 05:04 AM
07/30/11 05:04 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I am nowhere near the gearhead that most guys in this forum, so I am curious about the following:
Is the reason that these cams are so popular because their relatively low lift numbers allow the racer to retain the factory valvetrain? Most aftermarket cams seem to have higher lift #s in relation to the duration.
I was just thinking that the Mopar engineers were possibly looking to help the racer on a budget. Thoughts?
Re: Advantages of the MP 484 and 509 cams ? [Re: Kern Dog] #1042961
07/30/11 07:38 AM
07/30/11 07:38 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
First .. they are decent performing pieces. Second(and probably most important for Mopar) .. they are HUGE momey-makers for them. They run-off huge #'s when they make them .. to keep it a very profitable item.
Re: Advantages of the MP 484 and 509 cams ? [Re: dOoC] #1042962
07/30/11 09:54 AM
07/30/11 09:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
for a bracket car they are good, although there are newer grinds that will run w/ them. You need to have at least 10:1 to run them, 3800 stall and 3.91's. they like good heads and a free=flowing exhaust. You can build an easy low 12 second b-body w/ that cam, 10:1 440, headers some head work, intake and 750DP. Not much to it.
Coming soon!!!!
Re: Advantages of the MP 484 and 509 cams ? [Re: Kern Dog] #1042963
07/30/11 10:51 AM
07/30/11 10:51 AM
Az
Crizila Offline
Crizila  Offline
Az
Old grinds. I think the newer cams make better use of the 904 lifters.
Fastest 300
Re: Advantages of the MP 484 and 509 cams ? [Re: Crizila] #1042964
07/30/11 11:49 AM
07/30/11 11:49 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
i got the 484 in a 440 it sounds good but i agree the newer grinds have the advantage. i had an 03 voodoo cam not as lopey but much better low end my buddy had the 04 voodoo its a bit choppier at idle.i am going with the 05 next. cam lifters on ebay 182$.
Re: Advantages of the MP 484 and 509 cams ? [Re: Kern Dog] #1042965
07/30/11 01:05 PM
07/30/11 01:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
To each his own and some have proven them to work well.............I still use old Isky cams although some say I`d go quicker w/a new design.
Re: Advantages of the MP 484 and 509 cams ? [Re: Thumperdart] #1042966
07/30/11 01:17 PM
07/30/11 01:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The old mopar cams sell so well because they work OK and they say mopar on the box. The newer desighn cams work better and are cheaper but people think for some reason that useing a comp or lunati is like putting a chevy cam in their mopar when really it is quite the oposite, the old mopar cams are lobes stolen from chevy desighned cams that have to use the smaller lifter diameter witch limits how much lift you can get in a given duration, comp cams has mopar specific cams in witch the lobes would not work with a chevy lifter. The faster higher opening means less duration and that generally means more tq while the higher lift generally translates into more HP, sort of the same reasons roller cams are advantageous and as a matter of fact on very short duration cams a big mopar diameter flat tappet lifter can get the valve open higher and faster than a roller.
Re: Advantages of the MP 484 and 509 cams ? [Re: Thumperdart] #1042967
07/30/11 01:19 PM
07/30/11 01:19 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
I'd run the isky mega cam 292 244 505 108. I ran one in a
Chubby years ago and it was a bad boy!
74 dart sport 440 www.Csucarbs.com
Re: Advantages of the MP 484 and 509 cams ? [Re: shoebox] #1042968
07/30/11 03:19 PM
07/30/11 03:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually these MP cams were designed in the 60's and 70's and really have nothing to do with saving money. They were made for Mopar by Racer Brown originally and they were part of a package that Mopar would put out for the street cars and bracket racers for use in building good performance package. They would recommend the eng parts to use for stuff like a 12 second and 11 second build and so on. So Mopar had these cams ground to work for budget street racers and bracket racers. You could buy the cams themselfs and use them how ever you liked. But if you looked in the MP books they would have different builds in the books for big and small blocks and anywhere from 14 second to 10 second builds. And they all used one of the MP cams.
I believed they felt it really helped the average hot rodder in helping them select a cam for their Mopar build. Yes they are good cams and were some of the best back when they were put out. Today there are better cams but there is still nothing wrong with the MP cams if they fit your build.
I guess what I am trying to say is back when they were put out there was not alot of cams to use and these were good selection that Mopar recommended. But today there are alot more cams out there and alot more eng builders to help hot rodders select a cam for their build.
Bottom line is that yes the MP cams work fine and yes there are better cams to choose from nowadays so it is up to you or your eng builder to choose a cam. Nothing wrong choosing one of the Mopar cams if you feel like it fits your bill but you have many more modern cams to choose from now.
I myself like to use some of the MP cams in my budget builds as they work fine in the right combo. I used the .484 cam in a very mild 383 Dart and I really liked it. It ran 12.30's with 3.91's and was just a basic stock 383 with 9.5 comp and the normal bolt on's........headers , Eddy intake , Holley carb and MP ign.
I also used the .557 cam in my old 440 that was in my 63 and it was a mild 440 that ran a best of 11.49 @ 116.
I would suggest that if you dont know alot about cams talk with your eng builder or one of the reputable shops in your area about choosing the right cam for your combo. Ron
Re: Advantages of the MP 484 and 509 cams ? [Re: 383man] #1042969
07/30/11 04:13 PM
07/30/11 04:13 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Ron. Just as there were limited cam designs back then, it was similar in cylinder head choices.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Advantages of the MP 484 and 509 cams ? [Re: Mr.Yuck] #1042970
07/30/11 04:14 PM
07/30/11 04:14 PM
Pa
W
W7_Scamp Offline
W7_Scamp  Offline
W
Pa
10 to 1 3800 stall and 391 gears arent a must my old 440 had 9 to 1 a 3500 swap meet converter and 323 gears and worked great ran 11.7s in a 70 4 door valiant full interior blah blah blah great streetability unless ur too scared to turn a screw or two
Re: Advantages of the MP 484 and 509 cams ? [Re: Kern Dog] #1042971
07/30/11 04:39 PM
07/30/11 04:39 PM
Desert Tracker
Desert Tracker
This is true!! The Mopar engineers, as well as the sponsored racers and engine builders WERE helping the budget class/bracket racers to run stronger, back then.
Re: Advantages of the MP 484 and 509 cams ? [Re: shoebox] #1042972
07/31/11 01:55 AM
07/31/11 01:55 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
Re: Advantages of the MP 484 and 509 cams ? [Re: d-150] #1042973
07/31/11 11:48 AM
07/31/11 11:48 AM
New York
polyspheric Offline
polyspheric  Offline
New York
"not as lopey but much better low end" compares any 2 cams...
Boffin Emeritus
Re: Advantages of the MP 484 and 509 cams ? [Re: polyspheric] #1042974
07/31/11 12:06 PM
07/31/11 12:06 PM
boscosis Offline
super street
boscosis  Offline
super street
The dimensions on these cams are like a lot of older grinds - long duration with less lift than more modern cams. So ideally you're going to need a decent amount of static compression to make them work well but they seem to do OK even at low compression ratios also. We ran the 284 cam in a 9:1 440 with 906 heads at 3300# in a '68 Dart. Best time ever was 11.33 which we thought was OK. When we wanted to swap cams Dwayne Porter was nice enough to spend some time with me. He explained that they have a broad power curve and actually make pretty decent race cams. I remember him telling me also that they will RPM better than most modern "fast ramp" type cams making them a decent choice even now.
Re: Advantages of the MP 484 and 509 cams ? [Re: boscosis] #1042975
07/31/11 12:23 PM
07/31/11 12:23 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The 484 cam was generally considered the big Automatic cam and the 509 was considered the 4-speed cam - and yes they were designed to work with stock valve train and heads without modification to the guide heights. Good cams for there chosen purpose in the day considering the limited choice of converters and such. They were quality pieces at a reasonable price. but I agree there are much better choices today given your chosen combo.
Re: Advantages of the MP 484 and 509 cams ? [Re: Kern Dog] #1042976
07/31/11 02:08 PM
07/31/11 02:08 PM
My thoughts are that they are antiques and not worth running unless your really trying to save money on parts As already pointed out there are a lot of better cams out there today
