440 Source pushrod clearancing #1042718
07/29/11 05:20 PM
07/29/11 05:20 PM
Cab_Burge Offline OP
I finished grinding on the 440 source heads that I'm putting on a customers 383 bracket motor, they have a set of Crane 1.6 ratio ductile iron rockers and 3/8 pushrods. Picture one is of #4 intake port wall, some of them required more grinding than other ones All of the intake rockers required shimmimg away from the stock rocker shaft holdowns My message is make sure your pushrods clear all the way down, at closed and opened
Re: 440 Source pushrod clearancing [Re: Cab_Burge] #1042719
07/29/11 05:24 PM
07/29/11 05:24 PM
Picture two is of the #2 intake port wall. I didn't think of taking a picture of them before starting, for those that don't have a set yet, sorry. BTW, I didn't have to grind on my Eddy RPM at all with 1.5 rockers and I did have to grind on one intake port wall on another set that has the Harland Sharp 1.6 rockers
Re: 440 Source pushrod clearancing [Re: Cab_Burge] #1042720
07/29/11 06:10 PM
07/29/11 06:10 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Just done the same on mine. Here's a picture before I started.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 440 Source pushrod clearancing [Re: Mick70RR] #1042721
07/29/11 08:30 PM
07/29/11 08:30 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Just as a warning; the pushrod clearancing limits any porting you may want to in that area.
Re: 440 Source pushrod clearancing [Re: AAR-B4] #1042722
07/30/11 06:02 PM
07/30/11 06:02 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
My heads were CNC ported by MCH so I was worried I would break through the port wall. It's a shame the push rod holes couldn't have been opened up while the heads were at MCH.
Re: 440 Source pushrod clearancing [Re: Mick70RR] #1042723
07/30/11 06:06 PM
07/30/11 06:06 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
I agree, do they check guide clearence and such or just port and slap them back together?
Re: 440 Source pushrod clearancing [Re: Thor500] #1042724
07/30/11 06:35 PM
07/30/11 06:35 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
After porting the guide clearance is checked, valve spring installed height is checked and shimmed if necessary and he does a multi angle valve job. They should be ready to bolt on, unless you are using 3/8" push rods.
Re: 440 Source pushrod clearancing [Re: Mick70RR] #1042725
07/30/11 06:58 PM
07/30/11 06:58 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
To clearance push rods I would think MCH would need the block,rocker arms,cam,lifters and push rods. At times there isnt much material to work with.
Re: 440 Source pushrod clearancing [Re: Cab_Burge] #1042726
07/30/11 08:12 PM
07/30/11 08:12 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
I had cnc ported stealths put on my motor. It has 1.5 prw rockers on it. I know the builder said they were close with 3/8 push rods, but didnt hit guess I better check them myself.
Re: 440 Source pushrod clearancing [Re: AAR-B4] #1042727
07/30/11 09:51 PM
07/30/11 09:51 PM
I didn't try to remove material towards the port I removed material between the valve and the area they had already machine for pushrod clearances as well as I laid the already machined shoulder area over to clear the pushrods moving towards the valves due to the 1.6 ratio rockers moving the pushrods towards the rocker shafts some I also moved the rockers over on the shafts between .015 and .075 to help clear the pushrods and heads as well as centering the rocker pads over the valve centers If you want bigger ports buy a set of 440-1 and use the offset roller rockers to help align the pushrods off center with the offset intake rocker arms
