Using 16 volt battery??? #1042688
07/29/11 01:39 PM
07/29/11 01:39 PM
NY usa
540challenger Offline OP
NY usa
Why would you upgrade to a 16v battery?
When you do can you run a stock charging and wiring in your car or do you need to upgrade?
Re: Using 16 volt battery??? [Re: 540challenger] #1042689
07/29/11 02:27 PM
07/29/11 02:27 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
16 volts spin the engine over faster.
If you run a mag and or machanical injection it will start easier.
Also if you run electric pumps and fans they will run faster.
I run 16 volt with an alternator.
I run a step down on the fuel pump on the motor and when I run nitrous I run 16 volts to the fuel pump.
Re: Using 16 volt battery??? [Re: RADAMX] #1042690
07/29/11 03:25 PM
07/29/11 03:25 PM
NY usa
NY usa
Thank for the information.
Re: Using 16 volt battery??? [Re: 540challenger] #1042691
07/30/11 02:36 AM
07/30/11 02:36 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I switched to 16 volts last year and never stepped anything down.I also run an alternator. so when the car is running its at 18 volts plus. Motor spins over like a top.
Re: Using 16 volt battery??? [Re: OUTLAWSSAA] #1042692
07/30/11 01:00 PM
07/30/11 01:00 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
i've been fighting starter problems on my B1 500 plus cu motor for over a year---1-12 volt opt battery and alt---i've been dealing with it--until 2 months ago--i got very--very upset with it and got a 16 volt battery and charger---WOW it fires right up and i run everything off of the 16 volt battery---wish i would have dont this long ago.
ross
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: Using 16 volt battery??? [Re: ROSSIO] #1042693
07/30/11 07:25 PM
07/30/11 07:25 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
ross
Yep, what he said!!
