15 x 6 H wheel backspacing question #1042581
07/29/11 08:05 AM
07/29/11 08:05 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Hi Can anyone tell me what backspacing a 15 x 6 H wheel has from the mounting surface to the rim lip?
Re: 15 x 6 H wheel backspacing question [Re: Teamx] #1042582
07/29/11 04:25 PM
07/29/11 04:25 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
Not quite sure what "mounting surface" you are refereing to...if it's the backside of the center hub then it should be 4.5 inches I believe....I will confirm (by measurement) tonight if you want!
Re: 15 x 6 H wheel backspacing question [Re: LYNCHROAD69.5] #1042583
07/29/11 07:22 PM
07/29/11 07:22 PM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
The surface that makes contact with the drum thanks
Re: 15 x 6 H wheel backspacing question [Re: Teamx] #1042584
07/29/11 08:57 PM
07/29/11 08:57 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
15 x 6" H-wheels have 4" backspacing.
