dual point dist rebuild? #1042406
07/28/11 11:14 PM
07/28/11 11:14 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Does anybody sell parts to rebuild a dual point distributor. 70 cuda manual trans. Need a vacuum advance can and the plate the points sit on. Does pertronix make an ignitor for a prestolite dual point if so has anybody used it?
Re: dual point dist rebuild? [Re: 340swing] #1042407
07/28/11 11:28 PM
07/28/11 11:28 PM
Someone mentioned "Arizona parts" as a source for the 2 bronze bushings (top/bottom). High prob Board member "Joesixpack" has an NOS vac can avail.
