Re: Best ignition system for the street [Re: MR_P_BODY] #1042398
07/29/11 08:51 PM
07/29/11 08:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I ran an MSD Digital 6 on my mustang for several years, at that time I was the 8th owner over 6-7 years and the setup was the same the whole time. I used it to retard the timing for nitrous and relied on the rev limiter due to manual trans. It never missed a beat! I put one in my Barracuda as well but have limited use on it.
68 Barracuda Formula S 340
Re: Best ignition system for the street [Re: Bad340fish] #1042399
07/29/11 10:04 PM
07/29/11 10:04 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would use the Firecore50 mechanical distributor and coil with a MSD 6AL,the newer MSD 6AL units look really nice with great features
The Firecore50 distributor will fit with your Indy EZ heads and it's very easy to adjust with a movable plate instead of those loose rollers in the rotor
I have had this setup in my car for about 900 street/strip miles with Denso iridium plugs and could not be happier
Gus
64 Plymouth Savoy
Dana 60
Re: Best ignition system for the street [Re: Bad340fish] #1042400
07/29/11 10:04 PM
07/29/11 10:04 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
If you want to race at all, the digital 6 is tough to beat. It's got adjustable 2-step and high end limiters, along with an adjustable retard option for nitrous.
Re: Best ignition system for the street [Re: StealthWedge67] #1042401
07/29/11 10:19 PM
07/29/11 10:19 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
my car went 10.50s with an orange box but it did take a crap. then i ran the FBO for a while till a member here gave me a MSD 6al.
I will say this, my AF ratio at idle and cruise got leaner with the MSD so it works. car ran the same number at the track but idled better
Re: Best ignition system for the street [Re: 1969RR] #1042402
07/29/11 10:43 PM
07/29/11 10:43 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
The Mopar system is hard to beat.Plus you can get parts at any parts store.We've used the Mopar setup for over 30 years,its reliable and works great.
Nautilus Racing-
Re: Best ignition system for the street [Re: Chris2581] #1042403
07/29/11 11:04 PM
07/29/11 11:04 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
If clearance isnt an issue, I would go with the DUI Distributor.
It's a GM HEI put onto a mopar body. Everything is contained within the dizzy. One wire hookup, chuck the ballast resistor.. And someone mentioned breaking down...there are 50 GM HEI modules in stock at every parts store in america. lol
Just my personal favorite for it's simplicity.
They also make a small distributor that will clear any firewall that uses an external coil.
http://www.performancedistributors.com/
Re: Best ignition system for the street [Re: POS Dakota] #1042404
07/30/11 12:49 AM
07/30/11 12:49 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Another vote for the MSD Digital 6.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Best ignition system for the street [Re: CrAzYMoPaRGuY] #1042405
07/31/11 04:18 AM
07/31/11 04:18 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
I like the original FBO A688 system, and it has the capability to LOOK stock if that's an issue...?
I like the OLDER orange boxes, but the newer orange boxes scare me so much I would toss a chrome box on just to be safe. I've had a half dozen NEWER orange boxes fail, would not hot restart, and since then EVERYTHING I own has a chrome box on it, even my motorhome.
I went with an FBO A688 on my Jensen, so far it has been flawless, I'm truly impressed.
I'm building a 67 Charger street/strip car and looking at the new FBO system that doesn't require a ballast.
Anybody here ran the new FBO system yet??
Yes I do. I ran FBO A688D system in my 340cid race motor and useing A688 in my 318cid Van. Iam very pleased!
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
