Re: diagonal link ???-ladder bar suspension
[Re: moparx]
#1042332
07/28/11 09:52 PM
07/28/11 09:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Leave yourself about 3 threads showing with the lock nut on(thats after you center the housing to measure for the diagonal link)... must likely you wont ever move it once centered
[Re: moparx]
#1042334
07/28/11 10:27 PM
07/28/11 10:27 PM
MR_P_BODY
thanks mr. pbody. thats about what i was thinking. the rear is centered to about 1/16th now, and the brackets are attached to the driverside front bar bracket[5/8 bolt] and the pass side rear lower bracket[1/2 bolt]. i'm using 7/8 dom mild steel and 5/8 heims. maybe a little overkill, but i would rather be safe than sorry. i hate to fix broken stuff......
Is this a street car also... if so you might want to put a gusset from just above the lower mount point (where the ladder bar and the diagonal link mount) to the axle housing... this will take the flex out of it and save it from cracking the bracket
[Re: moparx]
#1042336
07/28/11 11:01 PM
07/28/11 11:01 PM
MR_P_BODY
the gussett sounds like a good idea. i had planned a 3/4 or so[1/8 wall] tube from the housing tube to the ladderbar brackets on both sides to eliminate flexing the brackets on the rear housing. are you sugesting adding a gussett to the diagonal link bracket ? i forgot to mention, i fabbed the diagonal link brackets from 1 1/2 x 3 x 1/4 wall tube, so they should be strong enough.
Your diagonal link bracket is a U that uses the lower ladder bar mounting hole... if you use tubing from the lower area to the housing thats fine... just anything to stiffen the bracket on cornering loads
