Octane booster question....... #1042301
07/28/11 08:18 PM
07/28/11 08:18 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
......if I put 91 octane and octane booster in my tank, would it somehow make the motor run hotter? She ran a little hot last night for no apparent reason.
I've been running Union 76 100 octane race gas, but had a bottle of O'Reilly Auto Parts brand booster in my garage that I wanted to try. Race gas is $7.79/gal here. Trying to save a little money. (please, no lectures) :
Mild 440 street motor, normal aspiration.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Octane booster question....... [Re: BFASTER] #1042302
07/28/11 08:26 PM
07/28/11 08:26 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I doubt the booster made it run hot. Exactly how "mild" is your 440 that you need race gas over pump 91??
Re: Octane booster question....... [Re: Dcuda69] #1042303
07/28/11 08:49 PM
07/28/11 08:49 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Don't NEED to....but it runs a helluva lot better than with anything else. Besides, 100 octane is really just "super Premium". (91 isn't what I would call Premium; used to be it was 93-94 octane)
Engine has MP .484 cam, aluminum Stealth heads, .030 over, Eddy RPM intake, stock elec. ignition and an old holley 750. About 9:1 cr.
Re: Octane booster question....... [Re: BFASTER] #1042304
07/28/11 09:00 PM
07/28/11 09:00 PM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
....My freshly built 440 ran terrible with an octane booster ! Once I ditched it she ran perfect !
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Octane booster question....... [Re: Plum440] #1042305
07/28/11 09:54 PM
07/28/11 09:54 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Me thinks I'll do the same!
Re: Octane booster question....... [Re: BFASTER] #1042306
07/28/11 10:27 PM
07/28/11 10:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
heres what i use. no problems easy install and it works. Not only can you run 91-93 and as much advance as you like, it adds about 25-40HP
http://www.snowperformance.net/product.php?pk=31
Coming soon!!!!
Re: Octane booster question....... [Re: BFASTER] #1042307
07/28/11 10:50 PM
07/28/11 10:50 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
OK...I fail to see how a alum. headed 9:1,484 cammed 440 runs "better" with 100 octane. But if it works for you..go for it!
My 10.3:1 Eddy headed,solid roller 470" runs fine on 91 pump swill
Re: Octane booster question....... [Re: Dcuda69] #1042308
07/28/11 11:14 PM
07/28/11 11:14 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
My 440 also runs fine with 91, never said it didn't. Seriously....do I need a "race" motor to benefit from running 100 octane?
Re: Octane booster question....... [Re: BFASTER] #1042309
07/28/11 11:32 PM
07/28/11 11:32 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Theoretically....yes. The only benefit you would see would be lead, is the 100 octane leaded?? If not I would doubt you'll see a difference in a 9:1 motor. Again just my
Re: Octane booster question....... [Re: Dcuda69] #1042310
07/29/11 12:34 AM
07/29/11 12:34 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
octane booster
pure bul- sh-t
I am truckless..
Re: Octane booster question....... [Re: BFASTER] #1042311
07/29/11 02:09 AM
07/29/11 02:09 AM
Alaska
73rrak Offline
73rrak  Offline
Alaska
I run a 3:1 premium 91 octane gas / race fuel mix in my 512 (11.3:1 compression stealth heads) Challenger. My car runs better with it but my 1/4 mile times went from 11 seconds to 11 minutes because I had to stop every 50 feet to get out and smell my exhaust....... God I love that smell.
I was only kidding about the 1/4 mile times I have no idea what it runs in a 1/4
Re: Octane booster question....... [Re: 73rrak] #1042312
07/29/11 08:25 AM
07/29/11 08:25 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
9.5:1 440. 91. When 100 is in it, it seems to get quieter. Or maybe it's phsycological. Wish I could get Sunoco 94 Ultra out here in green land.
Re: Octane booster question....... [Re: Dcuda69] #1042313
07/29/11 09:42 AM
07/29/11 09:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"OK...I fail to see how a alum. headed 9:1,484 cammed 440 runs "better" with 100 octane. But if it works for you..go for it!"
you know what's wierd. My 5.2 5 speed 95 dak sport w/ nothing more than a computer upgrade and headers ran much better on 104 (unleaded) mix w/ 93 than straight 93. The truck picked up a little over a tenth and It seemed to run smoother. I only did it because a buddy of mine suggested it. I was thinking it was over kill as well. Maybe because it was a hot day????
Re: Octane booster question....... [Re: Mr.Yuck] #1042314
07/29/11 09:51 AM
07/29/11 09:51 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I might understand that. Your computer(esp upgrsded)may add timing till it recognizes spark knock from a knock sensor. The 440 in the OP does not have that ability.
Re: Octane booster question....... [Re: Dcuda69] #1042315
07/29/11 09:53 AM
07/29/11 09:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
got ya... his should run fine on 93 even at 38* total.
Re: Octane booster question....... [Re: Mr.Yuck] #1042316
07/29/11 06:16 PM
07/29/11 06:16 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Octane is a measure of knock resistance. More octane will burn slower and not want to explode (knock). A higher octane will not produce more power. More powerful engines run the high test to match wild compression ratios, not because the gas has more bang in it.
Run the lowest octane that doesn't knock with your preferred spark advance.
Re: Octane booster question....... [Re: radar] #1042317
07/29/11 07:42 PM
07/29/11 07:42 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Thank you. A very sensible answer!
Re: Octane booster question....... [Re: BFASTER] #1042318
07/29/11 09:43 PM
07/29/11 09:43 PM
Eastern shore, New England
roadrunner69s Offline
My first GTX had a somewhat built engine though I never knew the exact specs. Maybe compression was between 10.1-10.5 to 1. It would ping at WOT on 93 octane and have a slight power lag at 1000-1400 rpm. Running a mix of Sunoco race gas to 93 octane boosted it to around 98-100. With that octane it had no pings, much improvement on the hesitation, and even ran a tad cooler.
I tried various octane "boosters" and none did a darn thing regardless of what they claimed. I'd even add the bottles when the tank was getting low to maximize the effect. A waste of $$. It was actually cheaper back then to add 1-2 gallons of race gas than it was to add an octane booster.
At least with the race gas you were getting a set qty of real octane.
RR69s
Re: Octane booster question....... [Re: Mr.Yuck] #1042319
10/09/11 12:50 PM
10/09/11 12:50 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I have heard of alcohol and/or water injection for years. I think that some aircraft used it in the 40's. Do you use it on the street or at the track? Any associated issues whatsoever?
Re: Octane booster question....... [Re: rbstroker] #1042320
10/09/11 03:50 PM
10/09/11 03:50 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Garrett used water-methanol injection in their TPE-331 turboprop engine mounted in a Fairchild Metroliner. 60% +/- 2% methanol, 40% +/- 2% water mixture. Increased shaft horsepower from 1000 to 1100 at sea level. The aircraft are still being used to this day at FedEx/UPS cargo feeder airlines.
