Re: Torsion bar lifespan?
[Re: JF_Moparts]
#104233
08/13/08 01:51 PM
08/13/08 01:51 PM
Posts: 84 ohio
2264PLY
ohio
Right before they break.Sorry couldn't resist.Unfortunely they usually don't get replaced until they do break.
[Re: 2264PLY]
#104234
08/13/08 02:18 PM
08/13/08 02:18 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Actually I think mine have been worn out for many years. I've just never done anything about them. Next time through the front end I plan on new bars and probably slightly larger.
[Re: CrazyD]
#104239
08/13/08 03:14 PM
08/13/08 03:14 PM
I'm curious to see how mine are going to hold. They are the original /6 bars and i'm using them when i put the 440 in
[Re: DaytonaTurbo]
#104241
08/13/08 04:07 PM
08/13/08 04:07 PM
Posts: 666 Anywhere the British Secret Se...
Moonraker
Still using original 318 t-bars under my 440. I like the way it handles so I've never felt a need to change them. Do the t-bars actually break? I've never seen that happen. I've seen the frame that holds the bars break, but never a broken bar itself. Not saying it can't happen or anything, but must not be all that common?
I've seen it happen a few times so its probably more common than you would think.
[Re: JF_Moparts]
#104242
08/13/08 06:00 PM
08/13/08 06:00 PM
Posts: 1,396 Mass
dgc333
Mass
How long should a pair of torsion bars last, and still provide a solid spring rate? The ones in my car were custom made in 1990 at 205 lb/inch and when they were new the car felt really responsive. Today it doesn't seem to be as responsive.
Could the anti-sway bar (also bought in 1990) be a factor here? Do they have a certain lifespan?
Thanks.
The spring rate will never change. The fatigue life is millions and millions of cycles. The normal range of motion will not come close to the yield strength.
What can happen? They can take a set requiring you crank on the adjustment bolt to reset the ride height but this does not change the spring rate. Damage to the bar can cause a stress riser that can result in the bar snapping. Impurities in the bar when manufactured can also result in bar failure.
The sway bar is subject to the same conditions but wouldn't be subject to taking a set.
[Re: jcc]
#104244
08/13/08 08:16 PM
08/13/08 08:16 PM
Posts: 589 Fortworth TX
mod5v
Fortworth TX
Thanks.
