Weld-on sway bar mounts for LCA's #1042267
07/28/11 06:06 PM
07/28/11 06:06 PM
MN
mkvien Offline OP
mkvien  Offline OP
MN
I see the ones from Hotchkis, any other options? I need them for a 68 Coronet, the Hotchkis ones are up over $60 with the shipping, just seeing what's out there. Thanks...
Re: Weld-on sway bar mounts for LCA's [Re: mkvien] #1042268
07/28/11 06:21 PM
07/28/11 06:21 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Some of the aftermarket bars supply a tab that bolts to the lower shock bolt...Hellwig for example.
Re: Weld-on sway bar mounts for LCA's [Re: Dcuda69] #1042269
07/28/11 06:25 PM
07/28/11 06:25 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
i took some thick stock steel and made a pattern off some stock ones from a buddies car, cut them out with an angle grinder and welded them up. You can't tell the difference. they even have that little angle to them.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
