What is the best option for A body to 4.5" bolt pattern #1042144
07/28/11 12:22 PM
07/28/11 12:22 PM
Tracy, New Brunswick, Canada
magnumcharger Offline OP
I have a 1968 Plymouth Barracuda. I'm planning on replicating the Super Stock appearance with this car. When the S/S cars were built, they had their own "special" spindles and hubs, quite unlike anything else found on an other A body.
My plan WAS to change over to a pair of 1973 Dart spindles, upper A-arms and disc brakes.
Recently I've found out that by doing this, the front track is increased significantly. This is not the look I'd like to have.
Has anybody done any other swap that keeps the track width at stock? (Like the S/S package)
Re: What is the best option for A body to 4.5" bolt pattern [Re: magnumcharger] #1042145
07/28/11 12:45 PM
07/28/11 12:45 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
You can get disc brake kits that will use your stock spindles and are bbp.
Re: What is the best option for A body to 4.5" bolt pattern [Re: magnumcharger] #1042146
07/28/11 09:22 PM
07/28/11 09:22 PM
NY NY
3
340duster340 Offline
NY NY
How significant is the difference? Is out not something that a different back space wheel couldn't fix?
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: What is the best option for A body to 4.5" bolt pattern [Re: 340duster340] #1042147
07/28/11 09:26 PM
07/28/11 09:26 PM
the house on the left.
cogen80 Offline
cogen80  Offline
isn't it only like 3/8 of an inch?
Re: What is the best option for A body to 4.5" bolt pattern [Re: cogen80] #1042148
07/28/11 10:23 PM
07/28/11 10:23 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
No, it's closer to 7/8" on each side:
See this linky
Re: What is the best option for A body to 4.5" bolt pattern [Re: Fab64] #1042149
07/28/11 10:44 PM
07/28/11 10:44 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
See this linky
I need to ditch my SBP disc then, My headers are close to the tires
That 7/8" would go a long ways on my car
Re: What is the best option for A body to 4.5" bolt pattern [Re: 69B3GT] #1042150
07/28/11 11:22 PM
07/28/11 11:22 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I have a similar thread going right now. I've just made the switch to '73-76 front discs, and now trying to decide which wheels to get. I've included pictures of my car with the same width wheels on front and rear, so you can see how it looks:
Front disc setup
Re: What is the best option for A body to 4.5" bolt pattern [Re: Fab64] #1042151
07/29/11 12:02 AM
07/29/11 12:02 AM
Actually, your thread is what got me thinking about the whole offset business. I've had the required parts to perform this swap longer than I've had my Barracuda!
Although you are happy with the result of this swap on your '67 Barracuda, for me that is just too much offset. 7/8" added to a reverse offset wheel is too much track for the look I'm aiming for. Check out this attached picture. My Barracuda on the left is as it sits right now, compared to yours. That front end is considerably different whereas the back track width appears to be the same for each car.
Re: What is the best option for A body to 4.5" bolt pattern [Re: magnumcharger] #1042152
07/29/11 12:39 AM
07/29/11 12:39 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the wider track is better for handling and the extra width isnt really significant...
I am truckless..
Re: What is the best option for A body to 4.5" bolt pattern [Re: magnumcharger] #1042153
07/29/11 02:34 AM
07/29/11 02:34 AM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Actually, I'm not satisfied with it. That's why I'm looking to possibly go to a narrower front wheel, with more backspacing, so it will pull them in a bit. Still not sure what I'll do.
Re: What is the best option for A body to 4.5" bolt pattern [Re: AdamR] #1042154
07/29/11 03:19 AM
07/29/11 03:19 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I used Wilwood's kit on my Duster - it increases track width too.
Ride eternal, shiny and chrome
Re: What is the best option for A body to 4.5" bolt pattern [Re: Fab64] #1042155
07/29/11 08:37 AM
07/29/11 08:37 AM
So I'm wondering...maybe by looking up the front bearing specs, and maybe the part number, there might be a possibility of finding another hub of similar dimensions that could fit onto the stock spindle? Maybe something from a Mustang, or an Explorer, or a Dakota, or ???
Or maybe - would it be possible to redrill the hub for a larger bolt pattern?
Re: What is the best option for A body to 4.5" bolt pattern [Re: magnumcharger] #1042156
07/29/11 09:00 AM
07/29/11 09:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I think so...and I *think* a similar era mustang K-H rotor has the same hearings/offset but larger bolt pattern....
2017 Grand Cherokee Overland
Re: What is the best option for A body to 4.5" bolt pattern [Re: patrick] #1042157
07/29/11 11:01 AM
07/29/11 11:01 AM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
On my 67 Dart it moved the wheels out far enough with my 3.5" skinnys that it limits me to a tiny 24.5" tall tire. I would like to run a 26" tire to offset my 275/60 DRs that are 28".
I dont much care for the stink bug look nor a ton of fender gap in the front which also BTW limits front end travel.I dont really want to clip the inside of the front fenders as I have seen on some cars.
I've looked without succes in finding a wheel with enough offset to clear the fenders. I did look at some billit wheels on a Mustang that looked as if a guy might be able to machine the hub of the wheel to create more backspacing and stil be plenty safe. The center of the wheel was nearly 2.5 inches thick.
Re: What is the best option for A body to 4.5" bolt pattern [Re: AdamR] #1042158
07/29/11 02:41 PM
07/29/11 02:41 PM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
I would be interested in where this kit is avaliable. My 69 dart has disk front but the small bp. I would like to go to the 4.5 bp....
Re: What is the best option for A body to 4.5" bolt pattern [Re: mopfried] #1042159
07/29/11 02:50 PM
07/29/11 02:50 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
I've also heard that you can take your SBP rotors and have the holes filled/redrilled for BBP from Moser or the like. I would think this would be the best and cheapest option.
Re: What is the best option for A body to 4.5" bolt pattern [Re: 2734bbl] #1042160
07/29/11 03:07 PM
07/29/11 03:07 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
You can use 68-69 B-body frt spindles and 73 A-body disc brk upper control arms. If you don't mind using drum brakes up front.
Re: What is the best option for A body to 4.5" bolt pattern [Re: rt66jim] #1042161
07/29/11 03:17 PM
07/29/11 03:17 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
For that matter, if you can stand to use the drum brakes, I drilled the hubs and drums to 4.5 pattern on my Dart. Drums slip on and off now also.
Re: What is the best option for A body to 4.5" bolt pattern [Re: magnumcharger] #1042162
07/30/11 01:52 PM
07/30/11 01:52 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
What do you have now, drums, or the sbp KH disks ?
I just recently converted my car from sbp disks to bbp.
I kept my Kelsey Hayes disk setup (spindles, calipers, pads,) but used a 67 Mustang unicast hub/rotor which is of course 4.5" bolt pattern.
There is some machining of the hub and rotor that has to be done. The machine work cost me $200 but it worked out great. There is a thread over at forabodiesonly . com in the brake section. Lots of good info there about this swap complete with pics. But read carefully cause some if the info can be a little confusing and there is some contradicting info.
The mustang hub and the sbp mopar disk hub use exactly the same bearings, but spacing between the two bearings is different and the seal is different. The hub has to be cut where the rear bearing race fits, so that the bearing sits deeper into the hub. THis lets the hub slider farther up onto the mopar spindle, this will get the disk to be centered in the caliper. The disk diameter will also need to be cut down a little. The mustang disk is 11.25" or so and it needs to be 11" or slightly less to fit inside the mopar caliper.
I have heard that Moser no longer does the "redrilling" thing with sbp rotors, they got rid of the machine they used to use for this.
Re: What is the best option for A body to 4.5" bolt pattern [Re: MileHighDart] #1042163
08/02/11 02:45 PM
08/02/11 02:45 PM
Thats some good information there boys. Thank you.
I'm going to continue my quest for alternatives and fill you in on my findings.
