What's a good carb/intake for this 528 hemi?
#1041854
07/28/11 12:27 AM
07/28/11 12:27 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Challenger, 3800lbs with me in it (it's a guess), 430 gear, 29" tire, 3500 stall 727, caltracs, 528 iron head hemi, gasket match and flashing cleaned up in ports, 10.3 compression, 2 1/8 headers, 295 duration 630 lift cam, stock ratio rockers. I have a pair of AFB's on it now with a Vanke modded intake. I'm not happy with the carbs at all so want to go to a single carb. Any suggestions?
Chris from New Jersey
Re: What's a good carb/intake for this 528 hemi?
[Re: fig426]
#1041856
07/28/11 03:25 AM
07/28/11 03:25 AM
Posts: 43,240 Bend,OR USA
Cab_Burge
528 C.I. Hemiroid, Big C.I. Elephant like big air, single plane intake with a 1050 or larger carb. I think Indy as well as possibly Stage V make a good single plane intake for your motor I'm assuming street driving
[Re: Cab_Burge]
#1041857
07/28/11 03:29 AM
07/28/11 03:29 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
Had the same combo couple of years back in my challenger. Same weight, ci, cr, gearing, tires caltracs, stall etc. only slightly more cam (667 lift) and oem allloy heads. Had a Barton single intake with 1050 dominator on top of it. Ran mid 10's.
Just watch the height with these bigger single 4bbl intakes as in hood clearence. No way the above would fit under a stock hood! I had a raised Hemi (68cuda) scoop to able to fit it.
[Re: 72Challenger]
#1041858
07/28/11 11:01 AM
07/28/11 11:01 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I have a 70 Challenger. It weighs 4000 lbs W/O me in it !!! I 'm using a modified INDY intake with 1150. Hood clearance is very close. I plan on converting to a Shaker to improve clearance and hope to run an air cleaner.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
