budget 440 ... 915 heads? talk me out of it
#1041795
07/27/11 11:16 PM
07/27/11 11:16 PM
Posts: 4,323 NY NY
340duster340
NY NY
i have a 440 with stock forged crank and LY rods, haven't had it apart yet, but i was planning on rebuild on the cheap with a set of 915 heads.
good idea / bad idea? is it worth putting any $ into the 915 heads or should i go right for a set of source heads?
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
Re: budget 440 ... 915 heads? talk me out of it
[Re: DaytonaTurbo]
#1041802
07/28/11 08:47 AM
07/28/11 08:47 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
My Stealths have been on 4 years.They are the first ones also.I changed the locks,retaniers and sorings for my .588 Comp solid cam.Machinist also back cut valves and cleaned them up a bit.No problems at all its street/ strip.Rocky
Chrysler Firepower
[Re: dOoC]
#1041805
07/28/11 02:38 PM
07/28/11 02:38 PM
therocks
Niles , Ohio
My old irons heads were decent.I had them redone first.200 bucks for valves,new guides,seals plus the springs etc whic I needed because of my cam.I had 500 in machine work and my guy is really reasonable on labor.He did open them up a bit but not a full port.I had almost 800 in parts and labor not including the springs,ertainers and keepers.The Stealths were a grand all new just upgraded the springs etc.They are lighter and flow more.Rocky
Chrysler Firepower
[Re: dOoC]
#1041806
07/28/11 02:48 PM
07/28/11 02:48 PM
DaytonaTurbo
Manitoba, Canada
BUT THEN the "effective" compression ratio will be cut-down using the alum heads.
That myth has been dyno proven to be nothing but an old wives tale.
[Re: DaytonaTurbo]
#1041807
07/28/11 03:09 PM
07/28/11 03:09 PM
Posts: 30,457 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Maybe up in cAnUkAdA ....but not here ! ...
[Re: dOoC]
#1041808
07/28/11 04:14 PM
07/28/11 04:14 PM
Posts: 2,172 Ohio
theclutcher
Ohio
915's
[Re: 340duster340]
#1041813
07/29/11 11:28 AM
07/29/11 11:28 AM
Posts: 7,861 Witness Protection Program
Kudakidd
Bang for the buck = 915's. I have them on my 440 and couldn't be happier. 2.08 I, 1.74 E and 76 cc chambers. Low end torque is impressive.
Did you do any work to them or just stock rebuild.
Obviously new valves, then just gasket matched the intake and exhaust ports.
