spring height-spring seats #1041793
07/27/11 11:13 PM
07/27/11 11:13 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Examinig tech on the 360-1 heads, they say they use 2in spring height and 1.550 spring seats
What do they mean ? is it installed heaight at 2 in ?
Dan
Re: spring height-spring seats [Re: Wedgeman] #1041794
07/28/11 01:17 AM
07/28/11 01:17 AM
Dan
They want you to use a spring with 2.00 installed height with a 1.550 diameter valve spring, you got it right I personally like to set up each spring on a vavle spring tester so I can get all of the springs within 5 lbs on the seat pressures, regardless of the exact heights
