Page 1 of 3 1 2 3
subframe connectors #1041744
07/27/11 11:08 PM
07/27/11 11:08 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
I know some connectors are pretty detailed with the custom fitting ridges, etc, but I'm just looking for some bolt-on or weld on straight square connectors. Anybody sell these fairly inexpensively?
Also, has anyone made their own????
Re: subframe connectors [Re: 68Bullit] #1041745
07/27/11 11:13 PM
07/27/11 11:13 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: subframe connectors [Re: 70AARcuda] #1041746
07/28/11 12:15 AM
07/28/11 12:15 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I just bought enough 2x2 to do some for my '64 Savoy. I wonder if I should build a couple of sets and see if there's much of a market? Maybe I can beat the existing prices...what would be a good price?
Re: subframe connectors [Re: topside] #1041747
07/28/11 12:19 AM
07/28/11 12:19 AM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
much to the chagrin of everyone here i got the MagnumForce double tube style ones. Bolt on each end and to the floors.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: subframe connectors [Re: 70AARcuda] #1041748
07/28/11 12:21 AM
07/28/11 12:21 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yup, I make my own out of 3x2" square tube .100 wall. I slot open the front part of the rear sub-frame in front of the front leaf spring perches. The 3x2 tube slides right in. The 3x2 tubes protrudes through the floor about 1" in height in the area where the rear passengers feet would go. I just cut the carpet's insulation over top of the connector and throw in my floor mats after and it's not noticeable. The part under the front passenger/driver feet area is under the floor so no modding needed there. Just weld it up to the torsion bar crossmember and in the back and you're done. Makes a huge difference in chassis rigidity. Before if I had one corner jacked up in the air, my doors would be very hard to open, now they open/close smooth even with one corner high up on a jack stand.
Here's a pic of my brother doing the same thing on his 66 charger while he was replacing rusted floor pans.
Re: subframe connectors [Re: 68Bullit] #1041749
07/28/11 08:00 AM
07/28/11 08:00 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I used some old Direct Connection frame connectors on my 71. They are regtangular, like 1 1/2" X 2.00" or so.
Very easy to put in with no floor cutting. They made a huge difference and are plenty stiff. You don't need 2 X 3" tubing, even 2 X 2" is overkill for a street car. IMO.
Yes you can make your own very easy.
Daytona turbo, please make your picture smaller so we don't have to scroll back and forth.
Re: subframe connectors [Re: Challenger 1] #1041750
07/28/11 08:11 AM
07/28/11 08:11 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
USCartool. Weld them or don't bother.
Re: subframe connectors [Re: MonGoo$e] #1041751
07/28/11 09:25 AM
07/28/11 09:25 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
getting the same ones for my charger. Figued it was asmall block car, but didn't want to cut up a clean floor. Great thing is you can bolt it in or weld, makes it pretty easy decision for the builder to decide.
Re: subframe connectors [Re: DennisH ] #1041752
07/28/11 09:34 AM
07/28/11 09:34 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
FULLY insert into the front and rear OEM stubs and cut into and through the floor and weld everywhere ..
OR don't bother....
Re: subframe connectors [Re: dOc !] #1041753
07/28/11 09:45 AM
07/28/11 09:45 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
OR don't bother....
Maybe for a race car,for a street car? Come on!! I did mine much like Challenger1. Used 1 1/2x 2 1/2 slid over the rear stub and welded front and rear. Never touched the floor pan. Made an entirely new car!!! Easiest and cheapest($40.00) mod I've done!
Re: subframe connectors [Re: Dcuda69] #1041754
07/28/11 09:49 AM
07/28/11 09:49 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
You will find ALL SORTS of flex just doing it that way...
LIFT UP one corner .... and see for yourself...
Re: subframe connectors [Re: dOc !] #1041755
07/28/11 09:53 AM
07/28/11 09:53 AM
Cincinnati, Ohio
Cincinnati, Ohio
BS How would you know??
Re: subframe connectors *DELETED* [Re: Challenger 1] #1041756
07/28/11 09:55 AM
07/28/11 09:55 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Post deleted by tboomer
Re: subframe connectors [Re: MonGoo$e] #1041757
07/28/11 09:59 AM
07/28/11 09:59 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Car I'm working on has the US Car Tool versions.
I didn't put them in, but heard they were a mother to fit to the floorpan. Fully welded they do look nice though.
My problem is they interfer big time with the parking brake system.
I'm still trying to figure out how to make them functional without looking all hookie.
Re: subframe connectors [Re: dOc !] #1041758
07/28/11 10:06 AM
07/28/11 10:06 AM
Cincinnati, Ohio
Cincinnati, Ohio
Hey DUMBbell ... try-it yourself.
You need to UPgrade your knowledge ...
I have done it myself, more than once. Like I said there is a huge difference between my cars that I do drive all the time. One has connectors and one doesn't. I can tell by driving them and jacking them up.
How many have you installed and driven???
I did the 3X2 through the floor on a 71 back in the early 80s, it was no better than the 71 I have now in the pictures above. It's a waste unless your gonna do roll bars for the track.
What have you done??
Re: subframe connectors [Re: dOc !] #1041759
07/28/11 10:07 AM
07/28/11 10:07 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I have many times! My simple cheap little connectors took care of 90% at least. Read the OP,he's looking for something simple.....Challenger1 and I gave him some options, you told him don't bother unless you hack the floor up
Re: subframe connectors [Re: gtx6970] #1041760
07/28/11 10:08 AM
07/28/11 10:08 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
These have an opening for the e brake cable.
http://www.autobodyspecialt.com/cgi-bin/commerce.cgi?preadd=action&key=MP-AR19S
Ive used the Mopar Perf connecters and just had to move were the cable goes through the torsion bar cross member
Re: subframe connectors [Re: Challenger 1] #1041761
07/28/11 10:11 AM
07/28/11 10:11 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
This statement is simply WRONG. Any chassis guy will tell you that. The pic that DT posted above is the CORRECT way of doing-it.
And other than that NON-competitive dragster you had ....I have done more work on cars in my life than you will ever THINK of doing.
WHY do you continue to step-in-it and have to eat your own words ?
U R nothing but a look-at-me SAD Sack
Re: subframe connectors [Re: 68Bullit] #1041762
07/28/11 10:17 AM
07/28/11 10:17 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Doc,what part of this question don't you get????
Re: subframe connectors [Re: Dcuda69] #1041763
07/28/11 10:20 AM
07/28/11 10:20 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Dc .. it was taken in a diff direction ... other people commented and I offered my
That's all .... and then DUMBbell came after me...AGAIN. And AGAIN showed his clownery.
Page 1 of 3 1 2 3
