Re: 383 Sonoramic Twin Turbo
[Re: 72sat]
#1041629
07/28/11 11:28 AM
07/28/11 11:28 AM
Posts: 2,255 IL
furious70
IL
I don't know what the 61 front subframe looks like but it might not be that bad. You might be able to use the 62-65 B body rear dump logs flipped side to side to face forward, mount the turbos there, run the downpipe under all that, and run the cold side up and back to each carb. Would be cool looking for sure!
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: NANKET]
#1041632
07/28/11 03:15 PM
07/28/11 03:15 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
It would look great, but the turbos would over ride the somoramic effect of the manifold, not really worth the trouble. There is enought plumbing on a factory set up before adding any turbo. The control arm mount is near the front exhaust ports so not much hope of backwards manifolds fitting.
what about rear mount turbos?
[Re: lewtot184]
#1041635
08/20/11 11:48 AM
08/20/11 11:48 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I think the trick with this set up would be synchronization. There is no common tract. The carb on the left could be seeing 5psi and the carb on the right could be seeing 15. Also, the left carb would be fed by the right turbo and vice/versa. Not things that can't be overcome, but something to think about. I think it would be a neat set up.
[Re: TRENDZ]
#1041636
08/20/11 02:35 PM
08/20/11 02:35 PM
Posts: 3,916 usa
lewtot184
usa
the intakes were designed with a balance tube. if they're not deleted everything should work.
[Re: lewtot184]
#1041639
08/21/11 10:01 PM
08/21/11 10:01 PM
Posts: 22,696 Bitopia
jcc
Bitopia
difference between pressure and vacuum
Well first, air fuel mixture inside an intake is never a complete vacum, it always has mass, it is also under most conditions moving, and the primary basis of the the long ram was using momentum of the above to extra pack the cylinder as the intake was closing. However there are a number of other variables, way over my head, regarding sonic pulses that also are the black magic of intake manifold design. They are both effected and tuned according to many variables, including cross section, surface roughness, geometry, wet or dry, fuel density, temperature, velocity, cam timing, compression, etc, etc. The main effected variable in turboing regarding ram manifold tuning would be a charge density increase, and maybe related varibale would be increase back pressure from the turbo, but I suspect that is more a cam timing variable. Therefore based on my simple explanation versus yours, I complelety disagree with your comment that a long ram intake "negates" the power adder.
[Re: jcc]
#1041640
08/22/11 11:57 AM
08/22/11 11:57 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I think he meant that the power adder negates the benefit of the long ram.
[Re: jcc]
#1041642
08/23/11 12:35 PM
08/23/11 12:35 PM
Posts: 2,255 IL
furious70
IL
I think 'negate' is a very poor word here. The more appropriate word IMO is 'override'. The turbos will override any ram effect with their greater ability to create increased pressure.
Whether the turbos would have any effect on the intake pulsing when the intake tract is under vacuum would be a very interesting question however. It would be in the same list of questions as 'were the long rams tuned only at WOT or at partial load'
[Re: Fury Fan]
#1041644
08/24/11 11:26 AM
08/24/11 11:26 AM
Posts: 2,255 IL
furious70
IL
That's going to happen in every engine though, right? It's just these manifolds were tuned for a specific range.
[Re: furious70]
#1041646
08/25/11 06:58 AM
08/25/11 06:58 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Based on what I know from turbocharging 2.2 and 2.5 engines I can assure you even at high boost pressures the runner tuning still impacts the engines operating range.
If anything it tends to magnify the effect.
[Re: jcc]
#1041649
08/25/11 11:31 PM
08/25/11 11:31 PM
Posts: 2,255 IL
furious70
IL
well, if you like to nitpick, the 2g wire, depending on the application, can reduce the resistance to a point of negligibility. To use the non-word you chose , irregardless it would be very interesting to see actual testing results from this rather than the conjecture most of us have to offer. Tom Vaught over on TMF would be a good guy to ask about this, being a career boost engineer.
