69Charger grille #1041579
07/27/11 06:15 PM
07/27/11 06:15 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I installed the grille today on a 69 Charger, and it seem like there should be a seal that goes between the fender and the grille on both sides . If there is a seal that goes there where can I get them, and can they be put in after the grille is installed.... thanks for any info...
Re: 69Charger grille [Re: JohnH] #1041580
07/27/11 07:33 PM
07/27/11 07:33 PM
phx, az.
J code Chargers Offline
phx, az.
There is no seal used on standard Charger grilles. The only seal/filler is used on the 69 Charger 500.
