PRW rocker ratio sb #1041568
07/27/11 06:13 PM
07/27/11 06:13 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Thought if someone would be interested.
I checked all my rockers for ratio and they are between 1.4915-1 and 1.526-1 witch is not all that bad exept i bought 1.6-1 ratio!
These are the stainless ones.
Well you get what you pay for.
Re: PRW rocker ratio sb [Re: sshemi] #1041569
07/27/11 08:18 PM
07/27/11 08:18 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I thought it may be like 1.53 on my 1.6 but i guess i was off.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: PRW rocker ratio sb [Re: 65signet] #1041570
07/27/11 08:48 PM
07/27/11 08:48 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
They also only leave room for a beehive spring. And yes the 1.6 rockers measure close to 1.5 ratio.
Re: PRW rocker ratio sb [Re: viperblue72] #1041571
07/28/11 10:18 AM
07/28/11 10:18 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
what are the 1,5s at???
Re: PRW rocker ratio sb [Re: sshemi] #1041572
07/28/11 04:32 PM
07/28/11 04:32 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
How Do get that measurement?
74 dart sport 440 www.Csucarbs.com
Re: PRW rocker ratio sb [Re: shoebox] #1041573
07/28/11 04:52 PM
07/28/11 04:52 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
with a magnetic stand and an indicator on one retainer and knowing the lobelift.
Re: PRW rocker ratio sb [Re: sshemi] #1041574
07/28/11 05:34 PM
07/28/11 05:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
did you use a hydraulic tappet or solid?
Re: PRW rocker ratio sb [Re: lewtot184] #1041575
07/28/11 05:43 PM
07/28/11 05:43 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
solid
Re: PRW rocker ratio sb [Re: sshemi] #1041576
07/28/11 08:17 PM
07/28/11 08:17 PM
SoCal
Brian Hafliger Offline
SoCal
Did you account for the lifter angle loss?
Brian Hafliger
Re: PRW rocker ratio sb [Re: Brian Hafliger] #1041577
07/28/11 08:43 PM
07/28/11 08:43 PM
Az
Crizila Offline
Crizila  Offline
Az
at max lift the rocker ratio won't be anywhere near 1.5 or 1.6.
Fastest 300
Re: PRW rocker ratio sb [Re: Crizila] #1041578
07/29/11 03:54 AM
07/29/11 03:54 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
If measuring at the retainer i get the true measurement.
On my w5 motor with Harland sharps the ratio was spot on.
Aldough they are more expensive.
