toasted cam bearings on new build #1041510
07/27/11 05:41 PM
07/27/11 05:41 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Hoping someone here can shed some light on this problem.
I just completed the build on my stroker motor it’s a 440, 0.60 over bore, 4.15 stroke crank and new rotating assembly,cam, roller rocker valevetrain etc… no apparent assembly issues, engine was pre-lubed with Joe Gibbs break in oil and assembled with assembly lube on all bearings.
The engine fired right up and ran for 25 minutes at 2,000 – 2,5000 RPM to break in the cam before the valvetrain stared seizing.
Now it’s torn back down and we have a mystery.
The valve spring seat pressure was not out of line, the cam broke in well, but 4 out of the five cam bearings are toast. One spun and three are severely “wiped “ including the #4 cam bearing that feeds the heads. The mains and rods look great, so there was no lack of oil or pressure, the engine had 70 PSI from the get-go. Since the mains and cam bearings feed from the same source, there would not be any reason oil was not reaching the cam bearings. New cam bearings were installed as part of the block prep and the cam turned freely in the bearings prior to final assembly. You can still see the oil hole (although mostly wiped) on the 3 bearings still in the block from the feed hole under the mains, so the hole was lined up correctly.
Any ideas?
Re: toasted cam bearings on new build [Re: 70Sbird] #1041511
07/27/11 05:47 PM
07/27/11 05:47 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
You didnt say what heads, but sometimes when running stock heads and they have not been cleaned out through the oil hole passage, it can have build up plugging the oil hole. This kinda happens when you took a head off the left bank and then installed it on the right side of the block. The oil passage sometimes is plugged up. I have seen it happen before, so I always check this area and clean everytime. Just something for you to check
Re: toasted cam bearings on new build [Re: Mopar-Al] #1041512
07/27/11 05:51 PM
07/27/11 05:51 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
thanks for the response, yes the heads were cleaned, oil passages reamed, and even double checked after teardown, the lack of oiling appears to have begun as the cam bearings were wiping and closing off the oil feed hole. the engine ran for about 25 minutes before we shut it down
Re: toasted cam bearings on new build [Re: 70Sbird] #1041513
07/27/11 07:06 PM
07/27/11 07:06 PM
Delray beach, Florida
P
Performance Only Offline
P
take a good close look to see if it there's debris embedded in the bearings. did any of the bearings have to be reamed or scraped to make the cam turn freely? that raises another question, if the cam didn't turn easily with 2 fingers during the assembly process, it was too tight.
can you take a picture of the cam bearings and the main bearings to post here? obviously, main bearings installed wrong could keep oil from the cam bearings too.
machine shop owner and engine builder
Re: toasted cam bearings on new build [Re: 70Sbird] #1041514
07/27/11 07:11 PM
07/27/11 07:11 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
get ur cam checked for straightness. a friend of mine had an engine built & there was babbit material on the edge of all his cam bearings. his cam was 1/4 thou out of being straight. something u should check. u must be getting oil to the top end cos u didn't mention about any burnt shafts.
Re: toasted cam bearings on new build [Re: rickraw] #1041515
07/27/11 07:18 PM
07/27/11 07:18 PM
P
P
not sure why .00025 TIR would bother anything.
the OP did say;
Re: toasted cam bearings on new build [Re: Performance Only] #1041516
07/27/11 07:45 PM
07/27/11 07:45 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
did you prime the engine after final assembly? debris in cam? cam walk to far? what does the intermediate shaft look like? also mentioned 1 brg spun. could it have spun on start up? cam brg installer too tight when installing brgs?
Re: toasted cam bearings on new build [Re: 9secondsatellite] #1041517
07/27/11 07:54 PM
07/27/11 07:54 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Any chance you have a cracked main webbing in the block? Block history? Ive seen this happen, all was good until motor got warm, broke in and things moved.
Turned out block was soon to be a two peice unit.
Re: toasted cam bearings on new build [Re: Performance Only] #1041518
07/27/11 09:48 PM
07/27/11 09:48 PM
Truckville, the capital of NY
85_Ram_4speed Offline
This is what I am going with. I don't build as many motors as some on here, but I have done a handfull of big blocks that had cam/cam bearing interference issues. My understanding is it is a fairly common issue on big blocks.
Regaurdless of what engine though, I always check how the cam spins before the chain goes on.
I now use an old cam I grooved the journals on (after I saw the idea here on Moparts ) so it fixes any interference issues. It works great.
Outcast Dodge guy.
Re: toasted cam bearings on new build [Re: 85_Ram_4speed] #1041519
07/28/11 06:10 PM
07/28/11 06:10 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Thanks for the replies everyone, I couldn't get back to my computer yesterday night so here are answers to some of your questions. The cam fit well and turned freely with 2 fingers, the block was prepped by a knowledgeable Mopar only engine builder and was checked for cracks and machined before the cam bearings were installed. The main and rod bearings are still in great shape, no excessive wear and no evidence of debris. The engine block was cleaned and prepped by the engine machinist, then I cleaned it again "just to be sure",including all the oil pasages from the lifter galley to the mains and cam bearings. The mains were installed correctly, with the groovs in the top, and the cam would still get oil regardless of the mains orientation and since the mains are good, I know this to be true. The engine was primed for about 10 minutes before ignition and I was turning the crank over by hand for about 5 minutes of that to be sure everything got oil.
It looks like the bearings began "wiping" and closing off the oil holes that feed the rockers and heads at some point of the 25 minutes it was running. The part that makes no sense is how can the cam bearings be destroyed if they had oil going to them, there was 70 psi of oil at startup and during the break-in.
Here is a pic of the cam bearings smearing themselves out of the bottom of their bores
Re: toasted cam bearings on new build [Re: 70Sbird] #1041520
07/28/11 06:18 PM
07/28/11 06:18 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Rod bearings and pistons:
Re: toasted cam bearings on new build [Re: 70Sbird] #1041521
07/28/11 06:19 PM
07/28/11 06:19 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
cam bearing closer up:
Re: toasted cam bearings on new build [Re: 70Sbird] #1041522
07/28/11 06:21 PM
07/28/11 06:21 PM
ill
dennismopar73 Offline
ill
did you verify oiling at both rocker arms before firng?
Re: toasted cam bearings on new build [Re: dennismopar73] #1041523
07/28/11 06:27 PM
07/28/11 06:27 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
yes, before and after. Even after the engine was shut down and we discovered the issues, I ran the oil pump with a drill and when the cam was indexed properly still got some oil appearing at the rocker roller tips
Re: toasted cam bearings on new build [Re: 70Sbird] #1041524
07/28/11 06:30 PM
07/28/11 06:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It looks like the cam bearing is tipped partly sideways
in there... are you sure its smeared as in turned to
a putty state... it would have to get very hot to do that
Re: toasted cam bearings on new build [Re: 70Sbird] #1041525
07/28/11 08:55 PM
07/28/11 08:55 PM
P
P
you know, perhaps the best way to approach this is by using just a smidgen of logic. there's really only two basic things that will cause what happened to your cam bearings. it's either lack of oil, or it's lack of clearance. of course lack of clearance can be for a large variety of reasons, but it's still a lack therof.
not to be too critical, but based on your pictures and the fact that you only have 25 minutes of run time on the engine. i think i'd go back and check the clearance on those mains as well. you really shouldn't have shiny edges and shiny wear spots like what the pictures show. basically they should look like brand new still if the clearances are correct.
so anyway, are you sure all the holes in the cam bearings were lined up with the oiling holes? one can't really see much of the cam bearings from the pictures you posted. best of luck with it. i'm sure you'll get it figured out.
Re: toasted cam bearings on new build [Re: Performance Only] #1041526
07/28/11 10:36 PM
07/28/11 10:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Makes good sense plus,in the one photo of the cyl., that seems like a lot of verticle scratches for such a short run time suggesting maybe it wasn`t perfectly clean or, as stated it passed some crud.
Re: toasted cam bearings on new build [Re: Thumperdart] #1041527
08/24/11 01:54 PM
08/24/11 01:54 PM
central Pa.
crsnles Offline
crsnles  Offline
central Pa.
Any one heard if he figured out his problem?
Re: toasted cam bearings on new build [Re: crsnles] #1041528
08/24/11 02:21 PM
08/24/11 02:21 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Never had a issue with cam bearings. I always check to make sure that the oil holes are lined up.. Even this if they are off a little bit will NOT hurt anything. Are the oil holes still lined up?
The engine looks trashy to me... whats all the pieces of blue and orange paint.
Cylinder walls look scored too. I have run engines for thousands of miles that look better. Bearings also dont look good IMO. They shouldnt even look like the crank has rolled over on them.
Pull the filter cut it apart, and the oil pump see what you find!
Good luck
Re: toasted cam bearings on new build [Re: Bob_Coomer] #1041529
08/24/11 03:01 PM
08/24/11 03:01 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Several years ago had the same thing happen to me! not sure what happened but the machine shop that installed the cam bearings bought me a brand new set of gold cranes cause the first set welded to the shaft....
Mopar Performance
