MAX LOBE LIFT IN SB #1041174
07/27/11 08:18 AM
07/27/11 08:18 AM
Queensland Australia
moparmacka Offline OP
What is the general rule of thumb for max lobe lift in a 59 deg 340 Resto block without uncovering the oil galleries? Running Comp 8043-16 roller lifters.....
Re: MAX LOBE LIFT IN SB [Re: moparmacka] #1041175
07/28/11 04:24 AM
07/28/11 04:24 AM
Re: MAX LOBE LIFT IN SB [Re: moparmacka] #1041176
07/28/11 06:53 AM
07/28/11 06:53 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I understand this was one of the features designed into the 8043 lifter but, nobody is
going to be able to give an absolute number. I've heard .430" lobe lift but, with the
way the 59º oil galleys are machined, it's too unreliable to guess.
Bushing the block is still the best way to approach it...............except a 48º block.
Re: MAX LOBE LIFT IN SB [Re: S/ST 3040] #1041177
07/28/11 07:30 AM
07/28/11 07:30 AM
I was mainly looking at the possibility of around the .390" - .400" region without bushing the bores.
Re: MAX LOBE LIFT IN SB [Re: moparmacka] #1041178
07/28/11 09:38 AM
07/28/11 09:38 AM
S/ST 3040 Offline
S/ST 3040  Offline
You will obviously want to check it while priming the engine but, .400" lobe should work with the 8043.
Re: MAX LOBE LIFT IN SB [Re: moparmacka] #1041179
07/28/11 02:39 PM
07/28/11 02:39 PM
How about tubing the block?
Re: MAX LOBE LIFT IN SB [Re: Cab_Burge] #1041180
07/28/11 05:51 PM
07/28/11 05:51 PM
Are you thinking tubing the block and using a different style lifter as the 8043 lifter requires pressure fed oil to feed the axles and for pushrod oiling......
Re: MAX LOBE LIFT IN SB [Re: moparmacka] #1041181
07/28/11 08:12 PM
07/28/11 08:12 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I always thought you had to bush the lifter bores to pushrod oil?
Alan Jones
Re: MAX LOBE LIFT IN SB [Re: LA360] #1041182
07/28/11 08:25 PM
07/28/11 08:25 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I have a tubed block and , while the axles will not get pressured oil, they will still work - just like the 828 lifters without the oil holes
no you can tube the block, bush the block or leave it - you will have to drill holes in the tubes / bushings to pushrod oil.
