ET vs. MPH question...
#1041128
07/27/11 02:24 AM
07/27/11 02:24 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Does this make sense to anyone? Cuz it sure doesn't to me...
Some background material: 70 Duster 416 12:1 Solid cam (268/276 @ .050) OLD Victor Holley 800 (848 cfm) RHS heads (improved about 10 cfm over as supplied on both sides) 1 3/4 headers
904 Converter with almost perfect slippage %
4.56's 29.5" tall tire
Weight, right at 3100 race ready
The best numbers are as follows (average of cold weather runs)
1.42 60' 6.41 1/8 mile ET 106.8 1/8 mile speed 10.14 1/4 mile ET 128.6 1/4 mile speed
See anything weird there? I do. I feel the car should be at least 130 at the stripe. Although is doesn't leave hard, the 1/8 mile speed tells me it's making decent power from 60' to 660'. Right?
Warmer weather the car has the same timeslip pattern, albeit a bit slower, of course.
Here's a question: With 4.56's at a finish line 7,000 RPM, do I have too much RPM for the small port heads?? I'm wondering if 4.30's would MPH better, WITHOUT giving up ET. It would change the flash of the converter, but I wonder if it would effect the high gear slippage at all??
Would lack of fuel VOLUME cause the low MPH? The fuel system does need updating if I were a betting man, I'd bet it is an issue. Driver says it's still pulling at the stripe, but I wonder it it's beginning to run out of steam for possibly the to reasons above????????????
Or Is my thinking in the wrong direction??
Like to hear some motor-head opinions...
Thanks!
Re: ET vs. MPH question...
[Re: cudadoug]
#1041129
07/27/11 03:15 AM
07/27/11 03:15 AM
Posts: 43,240 Bend,OR USA
Cab_Burge
Try jetting the carb. up enough to slow the car down in the 1/4. I had a similar problem with a Holley 850 DP, list # 4781-7, my car ran 10.32 at 129.7 MPH with .110 neeedles and seats in it I had treid jetting it up two jets sizes at the local 1/8 mile track and it didn't respond. I ended up changing the needles and seats to a set of .120 and tha car pick up .2 ET and almost two MPH at the local 1/8 mile track(2500 Ft elevation)I took it back back to the 1/4 mile track at Woodburn this last weekend (180 Ft. above sea level) with the same jetting as before the needles changes and the car slowed down to 10.44 at 126.03 MPH MPH I have a wideban on the car, it had shown that the car was going lean a little at the end of the 1/8 mile and really lean in the 1/4, the changes verified that is was starving for fuel, not enough to make the car nose over or miss, just not enough fuel supply to not respond the the bigger jets I did change the jetting back down two sizes and that helped a little, it was still way to fat with the new needles and seats I will work on that carb. later, I switched the carb(1050 Dominator) and intake (domimator intake flange manifold) this weekend at the track and the car ran 10.03 ET at 133.45 MPH several times, even in worst weather
[Re: Cab_Burge]
#1041130
07/27/11 05:04 AM
07/27/11 05:04 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I put my speed through the wallace calc and it came up with 10.14, mine is in shocks and tyres though. Do you have a dyno sheet for the motor, it's definitely laying down on the top end somewhere, what do you have for a fuel system. Mine is only 3/8 line, single holley black pump. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: cudadoug]
#1041131
07/27/11 08:45 AM
07/27/11 08:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Its probably your fuel supply... the cam should pull above the 7000 point so I dont believe its a gear issue... I have used 1 3/4" headers before and they worked to higher revs than your pulling... I would look at the fuel system from back to front and that includes the needle and seats as Cab said and make sure it flows the needed amount
[Re: theclutcher]
#1041134
07/27/11 12:04 PM
07/27/11 12:04 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
what i see is a combo that runs extremely well. the 4 inch crank takes a lot of head. those heads arent very big on a motor like that, if it was my car i would put a bigger carb on it and probably put less gear in it,never seen a 4 inch motor that pretty much didnt go faster the more carb you put on it. i suspect about 6500-6600 is peak power on that motor, so it just isnt going to pull hard at the big end at 7000 rpm, even my w5 422 motor was " flat" the last 125-150 feet or so from 7000-7400 crossing rpm. just my
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1041135
07/27/11 09:32 PM
07/27/11 09:32 PM
cudadoug
Thanks a bunch guys! I will sheepishly admit...never thought about the needle and seats. I "thought" I was jetted about right as more jet slows the car down. But the N's and S's are "stock" as for a 4780 carb. The fuel system will get re-plumbed from the regualtor to the carb before next time out, and then I'll be prepared to add bigger needles and seats and THEN start fooling with the jetting again. Yea, Don I'd like to run the car with a 1000 cfm 4150 carb just for grins as I agree with your theory, but one thing at a time...as time permits. It's also a little soft on timing at 32 degrees...hmmmmm...
[Re: Thumperdart]
#1041139
07/28/11 12:03 AM
07/28/11 12:03 AM
cudadoug
Enough air?? Never thought of that. It has a 6-bbl scoop, sealed very well to the carb. In fact I tried it without the air pan one outing and the car slowed exactly 1 tenth and just a tick over 1 MPH. We always run the car with an air cleaner also; a 5" tall 10" diameter K&N. Now that you've sparked that idea, I'm going to A) make sure it gets a good cleaning and B) try a run or two without it.
Hey, Dom...apples and oranges...we don't have the go-nads to drive it on the street like you do! If fact, I bet no one here drives a 9 second car on the street as much as you do!!
We're "happy" with the way it runs, especially since it's my first small block build, but being the motor guy, I'm never happy...LOL! I chased the elusive 9.99 time slip all winter and spring, just beating my head against the wall, but plan to go back to that this fall. (Come on late October!!)
[Re: cudadoug]
#1041142
07/28/11 02:10 AM
07/28/11 02:10 AM
Thumperdart
State of confusion
Looking back, I went a bit quicker/faster w/out my 3 1/2x 14" K&N filter and w/less timing than most run. It may be apples to oranges but some of you small-block guys haul a$$ for sure. I do however drive the hell out my car and I wouldn`t have it any other way. As I`ve said before; I`ll never own any car that I can`t street drive cos it`s just too damn much fun.
[Re: Mopar-Al]
#1041143
07/28/11 10:07 AM
07/28/11 10:07 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Uh, I believe he meant cfm flow not scoop. The head can only flow so much
yes thats what i meant,,thankyou
[Re: cudadoug]
#1041145
07/28/11 03:59 PM
07/28/11 03:59 PM
Posts: 7,506 Az
Crizila
Az
It could be a fuel problem, but I'm gonna lean towards too much gear, especially with those heads. Making a gear / tire diameter change might improve your speed, but it also might do zero for your ET.
Fastest 300
[Re: Crizila]
#1041146
07/28/11 08:19 PM
07/28/11 08:19 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Max out the pushrod pinch...slow the air down as much as possible and LAAAAAY the short turn back alot. Be carefull but it will go a ways.
Is the cam advanced at all?
Brian Hafliger
