Weatherstrip adhering to door in cold weather... #1041005
07/27/11 12:04 AM
07/27/11 12:04 AM
Vancouver, WA
MoparMarq Offline OP
Vancouver, WA
Just thought of it while replacing a part broken by a Home Depot guy putting plywood sheet in the Durango.
During cold weather (below freezing), the doors "adhere" to the weatherstrip, making it extremely difficult to get them open. To the point where I'm worried I'll break off a door handle trying to pull it open.
Anybody use any spray-on or wipe-on stuff on weatherstrip to eliminate this from happening?
As always, TIA.
-Marq
Re: Weatherstrip adhering to door in cold weather... [Re: MoparMarq] #1041006
07/27/11 12:37 AM
07/27/11 12:37 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
WD40 ,,, Lemon Pledge
I am truckless..
Re: Weatherstrip adhering to door in cold weather... [Re: 340SHORTY] #1041007
07/27/11 12:45 AM
07/27/11 12:45 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, a silicone lube or WD40, ArmorAll all work.
Re: Weatherstrip adhering to door in cold weather... [Re: MoparMarq] #1041008
07/27/11 02:17 PM
07/27/11 02:17 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I would try to rub a little clear silicone grease on them. This is what the factory recomendation is for weatherstrips, and will not damage them.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Weatherstrip adhering to door in cold weather... [Re: doctor_mopar] #1041009
07/27/11 09:01 PM
07/27/11 09:01 PM
Vancouver, WA
Vancouver, WA
I'll try the silicone grease this winter. Thanks for the replies.
