School me on adding brakes to my 8-3/4"
#1040842
07/26/11 10:30 PM
07/26/11 10:30 PM
Posts: 1,612 Vista, California
ChickMaggot
Vista, California
Guys,
I just picked up a bare 8-3/4" A-body housing. Also got a screamin' deal on a sure-grip 742 pig w/3.23. Now I need axles and brakes.
The finished unit will be going into a street car(Duster), mild 360, auto trans, driven a couple times a month if I have time.
Some say I should upgrade to 11" B-body brakes. Some say I may be able to transplant brakes from an 8-1/4" A-body 10x2.5" system. I'm looking to do whatever has the most readily available replacement parts.
Are there any considerations I should have when buying axles with respect to the size brakes I use? Who sells the best axles?
What consideration should be taken if I want to go with disc brakes? Any special prep to the housing needed?
Help me make this build as easy as possible.
Maggot
You can lead a gift horse to water, but you can't look in his mouth.
Re: School me on adding brakes to my 8-3/4"
[Re: ChickMaggot]
#1040843
07/26/11 11:42 PM
07/26/11 11:42 PM
RapidRobert
Yes several ways 2 go. If SBP up front I'd stay w the SBP in the rear & I see the axles regularly for ~ $75, the drums are faily common & the 1&3/4" shoes/hardware kits are still avail. If BBP up front could have Moser cut down a set of 1/2 Ton truck 8&3/4 axles (I've done it/works well) & use the common BBP 10" drum assy's which includes the 8&1/4 10" you mentioned. The 11" BBP rear drum brake assy is heavy & adds alot of unsprung weight & reportedly not alot of gain since the rears do less work, me I'd go (rear) disc if only for the bling
[Re: RapidRobert]
#1040844
07/27/11 12:40 AM
07/27/11 12:40 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
contact Dr Diff here on the board,, he will set you up....
I am truckless..
[Re: 340SHORTY]
#1040845
07/27/11 07:11 AM
07/27/11 07:11 AM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
I'd go overkill with Police drums on the rear (11x2 IIRC). The fronts....discs. I'd personally move up to the Big Bolt pattern if you havent already and go get the front end off of a 74/75 A-Body.
Dr. Diff has some nice setups here too. I wanted one but with the amount of miles I drive the car every year. I wouldn't be doing much difference than the brakes I have now. Rear disc's were my goal but you do 70% of your braking with the front anyways.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: ChickMaggot]
#1040846
07/27/11 02:03 PM
07/27/11 02:03 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I would not go with too heavy and large brakes. The 10 inch brakes and backing plates off the 8 1/4 will work fine ( large bolt pattern). I had trouble with respline axles. Doctor Diff sold me some nice new big bolt pattern axles with bearings installed. He is the man to speak to, and will get you on the best path with the whole installation !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: ahy]
#1040848
07/28/11 10:26 AM
07/28/11 10:26 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I plan to use disc brakes on the rear when I get it back up and running.
I'm tired of "self-adjusting" drum brakes that don't self adjust, forcing you to constantly be tweaking them and adjusting them manually.
disc brakes are nice simply from the maintenance standpoint. toss a set of pads in, run them till they're gone, push the pistons back out, and put new pads in. never have to worry about an adjuster not working, forcing you to go click the star wheel manually.
**Photobucket sucks**
[Re: 70Cuda383]
#1040850
07/28/11 06:04 PM
07/28/11 06:04 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Dr. Diff's 10.7" 8-3/4 rear setup here.
[Re: MoparMarq]
#1040851
07/30/11 12:53 AM
07/30/11 12:53 AM
ChickMaggot
Vista, California
Guys,
Will backing plates from a '76 7-1/4" rear with 10x2.5" brakes swap over to the 8-3/4" rear?
