Re: Good guy alert, Scott Smith, HARMS, 340 TQ carb resto!!
[Re: JulesdaWiperman]
#1040759
08/31/11 11:09 PM
08/31/11 11:09 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know Jules, it might be? Chris....? *Jules, I am still prepping my load of Duster parts which will be heading your way sometime soon!
[Re: cdp]
#1040767
09/20/11 04:50 PM
09/20/11 04:50 PM
Posts: 1,185 Nanaimo, BC
NOrrTH
Nanaimo, BC
Excuse my lack of knowledge but do these carbs need a solinoid? Isn't there one already attached to the starter motor or does this replace it? The reason I'm asking is I have the same carb 4968S and it doesn't have a solinoid. I think someone said they were only needed if you had factory air conditioning.
'71 GTX N96 auto 3:55
'74 Challenger 440+6 4spd 4:10
'71 Duster 340 auto 4:10
[Re: NOrrTH]
#1040768
09/20/11 05:50 PM
09/20/11 05:50 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
By 71 most applications had a carb solenoid to help comply with ever increasing emmisions requirements.
[Re: NOrrTH]
#1040770
09/20/11 11:22 PM
09/20/11 11:22 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
The parts book indicates that the 4968S does come with a solenoid, part number is: 3438 303. The book also shows a bracket, etc for the solenoid as being needed.
[Re: Paul]
#1040775
09/22/11 03:33 PM
09/22/11 03:33 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Are they engine tested after restoration?
Do you do Holley carbs?
Yes, every carb is test run for leaks or build issues and adjusted on a running mule engine before shipping.
Yes, I can restore any 2, 4, or 6 BBL, Holley, Carter AVS, AFB, WCFB, or Thermo-Quad, and any Rochester carburetor.
Any other questions or special requests feel free to inquire.
[Re: dmoore]
#1040776
09/23/11 08:43 PM
09/23/11 08:43 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
My current 72 340 Duster has two..........the idle stop solenoid & the fast idle solenoid for the A/C.......of which I am looking for...
The idle stop solenoid for a 72 is harder to find than the 71, i sold one about 6 months ago for $$$$$$$$$. you can bet i'll keep my eyes peeled for another!!
