Exhaust manifold gasket #1040471
07/26/11 02:25 PM
07/26/11 02:25 PM
Home of the Dream Cruise
FPD031 Offline OP
FPD031  Offline OP
I'm putting the stock manifolds back on and the new gaskets have normal gasket material on one side and some sort of silver covering on the other. Which side goes to the head?
Thanks,
Re: Exhaust manifold gasket [Re: FPD031] #1040472
07/26/11 02:40 PM
07/26/11 02:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I always put them foil side out but It doesn't really matter ... flip a coin
Re: Exhaust manifold gasket [Re: FPD031] #1040473
07/26/11 02:43 PM
07/26/11 02:43 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
If your using stock exhaust manifolds you probably dont need to use them at all. The factory didn't.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Exhaust manifold gasket [Re: HemiRick] #1040474
07/26/11 03:00 PM
07/26/11 03:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
You'll never find a Mopar PN for it because they don't exist, its and aftermarket stuff
