Oil choice for flat tappet cam ? #1040362
07/26/11 12:42 PM
07/26/11 12:42 PM
Forest Grove,Oregon
beepbeepdon Offline OP
Forest Grove,Oregon
Hi All
I wanted some input as to who uses what oil with their flat tappet cam.I have a Hughes Racing flat tappet cam and engaged them and they recommend running either Joe Gibbs Hot Rod conventional or synthetic. I have been using Hughes Extreme Pressure additive and conv Pennzoil 20W/50 but from what I am told that I should start using an oil with high zinc content designed in the oil..I am just curious what you all use. I want to protect my engine/investment as much as possible....and not end up with a flat cam......Any input would be appreciated....Thanks ......btw The guys at Hughes are very professional and have always answered my questions and concerns
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040363
07/26/11 12:44 PM
07/26/11 12:44 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Joe Gibbs-they did all there research and it is the best oil out there.
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040364
07/26/11 12:50 PM
07/26/11 12:50 PM
Super Scamp Offline
Super Scamp  Offline
Brad Penn 20/50 High Zinc. Oil Made in USA.!!
Just One Man's Opinion Mopar Mafia Racing
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040365
07/26/11 12:51 PM
07/26/11 12:51 PM
Locomotion Offline
Locomotion  Offline
You'll get plenty of answeres, the way I do it is.....
Break it in with a quality high zinc conventional oil, even adding a break-in additive, like from Comp Cams. However, Amsoil now has their own break-in oil!
Amsoil break-in oil
Then use a high zinc synthetic, which a wide variety can be found through Amsoil as well. I use their Dominator 5w-20 in my race car.
Amsoil tech bulletin on flat tappen cams and zinc
Amsoil source and additional info
Re: Oil choice for flat tappet cam ? [Re: Locomotion] #1040366
07/26/11 01:17 PM
07/26/11 01:17 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Brad Penn
Re: Oil choice for flat tappet cam ? [Re: SILVER67] #1040367
07/26/11 01:24 PM
07/26/11 01:24 PM
Delray beach, Florida
P
Performance Only Offline
P
i use the Brad Penn break in oil along with an additive for camshaft break in. after that, just the regular Brad Penn oil in the appropriate weight designation for the application.
machine shop owner and engine builder
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040368
07/26/11 01:46 PM
07/26/11 01:46 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
You never said how big a lift or spring pressure you are running but if you follow hughes advice when breaking it in you won't have any problems.I ran a couple different flat cams from hughes before putting a roller in, and have always used brad penn 20w50
Re: Oil choice for flat tappet cam ? [Re: mistress] #1040369
07/26/11 01:59 PM
07/26/11 01:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just broke in my cam about 2 months ago. It is .634 and .630 lift with 1.6 rockers and I used Valvoline Racing oil with Comp break in additive. I did remove the inner springs when breaking in the cam but all went great with no problems at all. Ron
Re: Oil choice for flat tappet cam ? [Re: Biginchmopar] #1040370
07/26/11 02:02 PM
07/26/11 02:02 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I agree,I use the Gibbs assembly lube and break in oil.
As far as oil to use after the break in,I have been using the Gibbs Racing mineral oil,and have had absolutely no wear issues with flat tappet cam and lifter set ups.
If you go exactly by what Gibbs tells you,you don't want to add any additives to his stuff.
As far as adding a bottle of break in additive to other oils,a lot of guys have luck with it but I am getting away from that myself after a little research on how the zddp additives are blended.
I think it is better to have something designed for what you need than to mix your own.
Too much money invested in a good engine to comprimise with oils and additives anymore.
Keith
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040371
07/26/11 03:38 PM
07/26/11 03:38 PM
Forest Grove,Oregon
Forest Grove,Oregon
Thanks for all the responses......The motor was broke in on an engine dyno(inner springs removed) using 30w Pennzoil and Hughes additive....Since then made about 20 passes or so down the track using Pennzoil 20W50 + additive and was looking to change to a straight oil....So thanks again!!!
btw....Intake Valve Lift 1.6 .614"
Ext Valve Lift 1.6 .626"
Hughes springs,solid lifters & Hughes roller rocker setup
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040372
07/26/11 03:55 PM
07/26/11 03:55 PM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
Valvoline VR1 has high zinc content (14ppm) and phosphorus (13).
http://www.valvoline.com/pdf/VR-1%20Racing%20Motor%20Oil.pdf
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040373
07/26/11 04:01 PM
07/26/11 04:01 PM
Az
Crizila Offline
Crizila  Offline
Az
Royal Purple full synthetic and Hughes additive. Running over a .6" lift Hyd. After 3 years ( and 2 sets of springs ), NO appreciative valve train ware.
Fastest 300
Re: Oil choice for flat tappet cam ? [Re: Crizila] #1040374
07/26/11 06:13 PM
07/26/11 06:13 PM
Guitar Jones Online laugh2
I had a .672 lift (1.6 rocker) Hughes flat tappet for over 20 years and it's still good. I even had it in 2 different blocks with the same lifters. I used just the moly lube initially for break in with cheap convential oil and just the outer springs. After break in I added the inner springs and changed to Mobil 1 10w30. I had to add more spring pressure as it would valve float at 7500. I ended up running 140 on the seat and 440 over the nose with nothing more than 10w30 Mobil 1 all it's life. It is still a very usable cam. I was going to use it again in my 408 but a killer deal cam up on a solid roller with only 10 dyno pulls on it so that is what went into the new engine.
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040375
07/26/11 07:14 PM
07/26/11 07:14 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Hi All
Okay, since you specifically asked for "any input", here is mine.
There's a lot of marketing hype, personal opinion, and overall bias out there regarding motor oils.
If you like, you can look to an ASTM approved bench test for a preliminary evaluation of the overall anti-wear package of a few of the most popular high performance motor oils on the market.
Click here for LARGER IMAGE
American Society of Testing and Materials(ASTM)
ASTM D4172 - 94(2010) Standard Test Method for Wear Preventive Characteristics of Lubricating Fluid (Four-Ball Method)
Significance and Use:
This test method can be used to determine the relative wear preventive properties of lubricating fluids in sliding contact under the prescribed test conditions. No attempt has been made to correlate this test with balls in rolling contact. The user of this test method should determine to his own satisfaction whether results of this test procedure correlate with field performance or other bench test machines..
1. Scope
1.1 This test method covers a procedure for making a preliminary evaluation of the anti-wear properties of fluid lubricants in sliding contact by means of the Four-Ball Wear Test Machine.
2. Test Conditions
132 pounds of applied pressure - 302 degrees Fahrenheit operating temperature - 1800 rpm - 1 hour duration.
Re: Oil choice for flat tappet cam ? [Re: CompSyn] #1040376
07/26/11 08:11 PM
07/26/11 08:11 PM
IN
ahy Offline
ahy  Offline
IN
I've had good results with Rotella T 15W40 plus STP.
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040377
07/26/11 08:49 PM
07/26/11 08:49 PM
NC
440Jim Offline
440Jim  Offline
NC
Brad Penn racing semi-synthetic.
For added protectgion use a zinc additive (ZDDPlus etc).
There are a few good oils for that. But the price can vary a lot between them.
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040378
07/27/11 12:03 PM
07/27/11 12:03 PM
Forest Grove,Oregon
Forest Grove,Oregon
One more question if I may......Will switching from Pennzoil 20W50 conventional + additive to Joe Gibbs Full synthetic HR-4 10W30 after 20 or so passes harm the cam or motor....We broke it in on Pennzoil 30W + additive.....Thanks again everyone for all the info,I really appreciate it
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040379
07/27/11 10:37 PM
07/27/11 10:37 PM
Des Moines, IA
CoreyWilson Offline
CoreyWilson  Offline
Des Moines, IA
I've been a fan of CenPeCo oil for a number of years now. A lot of truck pullers use their oil and swear by it. Talking to the rep, the 20w50 Race oil has 2400ppm zinc and 2200ppm of phosphate. Gotta order it through a dealer, but our local rep delivers all over the state with no delivery charge.
Re: Oil choice for flat tappet cam ? [Re: beepbeepdon] #1040380
07/27/11 11:19 PM
07/27/11 11:19 PM
IN
ahy Offline
ahy  Offline
IN
I don't think the switch from conventional to synthetic in general will hurt, however, that's a big change in viscosity. What does the engine want/need in terms of viscosity? Is 10W30 enough? Also, what are the zinc specs on the Joe Gibbs synthetic? If over 1300-1400 PPM should be ok in that area.
