Restoring exhaust manifolds #1040230
07/25/11 11:55 PM
07/25/11 11:55 PM
desomod Offline OP
desomod  Offline OP
I have a set of 1970 340 exhaust manifolds that back in the day were ground smoothe and chromed! I want to try to restore them and use on my T/A to replace the Hooker's and return the engine bay back to more stock looking. My question is how to get rid of the chrome and is there a way to restore the rough cast look? Replacing the manifolds is way to pricey. I have seen $500 and $600 at a recent swap meet for a pair!
Re: Restoring exhaust manifolds [Re: desomod] #1040231
07/26/11 12:20 AM
07/26/11 12:20 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Are the numbers ground off? If so why bother?
Removing chrome can be difficult, a chrome shop can reverse the chrome process and remove the chrome (the top clear color over the nickel and copper) but it won't usually remove the nickel and copper plate, that needs to be mechanically stripped (grinding, sand blasting, etc.). you can re-texture cast iron a few ways, none will likely be absalutely convincing as far as originallity but could look close. A needle scaler will do it and so will sand blasting to a point.
My advice? Sell them to a hot rod guy (no they won't bring as much as nice originals) take the loss and step up to a nice pair of unmodified originals.
Re: Restoring exhaust manifolds [Re: ScottSmith_Harms] #1040232
07/26/11 12:47 AM
07/26/11 12:47 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Scott nailed it. Undoing the polishing & chroming still won't give you the correct look, and would be too much bother & expense; better to sell yours and shop around. Some Chevy guy probably has a pair he'd take $100 for. I'm not slamming Chevy guys, but there are deals to be had on almost anything if you have the time and look around.
Re: Restoring exhaust manifolds [Re: desomod] #1040233
07/26/11 07:20 AM
07/26/11 07:20 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sell the chrome manifolds, if they're nice, they'll sell, sell the Hookers as well, the cash made, invest in a set of NEW/repro 340 manifolds from Snobar..for $550, plus you'll need the heat shield, that's another $150 IIRC.....340 stuff ain't cheap
Re: Restoring exhaust manifolds [Re: DAYCLONA] #1040234
07/26/11 09:44 AM
07/26/11 09:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The reproductions I saw lacked correct casting numbers, dates, etc. I wouldn't pay that kind of money for a part unless it was spot on. Nice originals are out there all the time for the same money or less and will hold thier value better than reproductions will
Re: Restoring exhaust manifolds [Re: ScottSmith_Harms] #1040235
07/26/11 09:48 AM
07/26/11 09:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Restoring exhaust manifolds [Re: JohnRR] #1040236
07/26/11 08:17 PM
07/26/11 08:17 PM
desomod Offline OP
desomod  Offline OP
Thanks for the ideas. Your right, the #'s have been ground off and having the correct ones is my first choice. The T/A is very nice with the exception of the engine compartment. It had been used as a show car in the mid to late '70s so nearly everything that can be removed was chromed, even the front suspension! Pretty hot in the day I suppose but I prefer the stock look. I also think it will be more valuable that way. Anyone with date correct small block engine accessories? I'm buying!
