Re: 727 failure (pics) #99
04/04/03 03:16 AM
04/04/03 03:16 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Hey JohnRR, the bolt in sprag was $33. The Red-Head anchors from which I pulled the sleeves from cost $1.65. It took me 20 minutes to install. If I told you I spent $13 on a brand new output shaft support, you'd probably tell me I wasted my money on that too. Get lost!
excuse me ???? at what point did i say that you wasted money ??? i only paid 26 bucks for my bolt in and i made sleeves from a piece of 3 inch tubing , though i paid more for the rear support , so what its not going to stop the trans from blowing to pieces .
my comments were in reply to your concern of hurting your matching number trans . none of the parts your purchased are going to do a thing to stop a front drum explosion or any of the damage that is shown in the pictures above .
whats your matching number matching number trans worth if its broken in 2 ???
Re: 727 failure (pics) [Re: JohnRR] #100
04/04/03 06:17 AM
04/04/03 06:17 AM
Anonymous OP
Anonymous OP
We're breaking parts together .... I just replaced my Tailshaft from last weekends expolits. Dvorak put a LARGE (non-standard) pinion nut on the new pinion ... which collided with 1350 joint a some critical pinion angle ... busted a cap ... set up a small vibration (not that I could feel it) and broke the TailShaft housing. My fault for NOT checking everything more closely. Oh how a $5 part can ruin your day! I put a PROPER Pinion Nut and Washer and rechecked it's clearance thrice.
Gary, get a Low Band Apply VB and you'll really minimize chance that you'll bust a sprag ever again. Low Band Apply saves sprags and feet. That boltin sprag is ONLY to save the case. Put that Blanket ON!
Re: 727 failure (pics) #101
04/04/03 09:05 AM
04/04/03 09:05 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
"Oh, the humanity".
Re: 727 failure (pics) #102
04/04/03 09:13 AM
04/04/03 09:13 AM
Anonymous OP
Anonymous OP
Posted by Harpo: "Gary, get a Low Band Apply VB and you'll really minimize chance that you'll bust a sprag ever again. Low Band Apply saves sprags and feet. That boltin sprag is ONLY to save the case. Put that Blanket ON! "
Harpo, I think the new Griner valvebody may have low band apply. It does make me somewhat nervous though. I never thought much of it, but Chuck from Best Machine was telling me that a low band apply valve body can be scary in some situations. Lets say you launch the car and something happens or you get squirrely. When you get out of it, all of the cars weight dives to the front.. We'll see how it goes if the Griner is low band apply..
Re: 727 failure (pics) #103
04/04/03 09:17 AM
04/04/03 09:17 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Dude Sweet!.......... .I mean that's terrible! Sorry to hear about your lose. You get a Camera? I'm not SLURP good SLURP enough SLURP for you anymore? SLURP.
Re: 727 failure (pics) #104
04/04/03 09:54 AM
04/04/03 09:54 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
Hello,
also front band strut bent from line pressure above 120 or so lbs. what i have done is double up with 2 struts welded togeather. i still refuse to run powerglide, just went 8.87 151mph last weekend at US-13 in delaware with torqueflite
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 727 failure (pics) #105
04/04/03 11:10 AM
04/04/03 11:10 AM
Anonymous OP
Anonymous OP
I guess in the event of a worst case where you break an axle at 6000rpm just prior to 1-2 shift w/ a spool, and the wheels off the ground and jump OFF the throttle it may be a guaranteed handful. When you get out of it under those conditions under good traction, in a No-Band apply VB, it's time to tear the tranny apart. That's why the Non-low Band Apply units have NO 1st gear braking. The braking is the Low/REV band apply.
When I broke my drive shaft last year ... I launch ... it pulls the wheels up .... BANG ... rattle rattle bang bang. I pulled the transmission and checked the Over-running clutch finding no damage, all due to Low Band Apply. IMO It's inherently stronger by design.
Re: 727 failure (pics) #106
04/04/03 01:30 PM
04/04/03 01:30 PM
Anonymous OP
Anonymous OP
Posted by Harpo: "I launch ... it pulls the wheels up .... BANG ... rattle rattle bang bang. "
Oh man!! I'm having flash backs!! LOL
