Re: 05 Neon ?
[Re: formula_s]
#1039943
07/25/11 10:31 PM
07/25/11 10:31 PM
Posts: 2,094 oberlin, Ohio
Rapid340
oberlin, Ohio
Going from memory, I think it is 19mm.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 05 Neon ?
[Re: formula_s]
#1039947
07/26/11 03:14 PM
07/26/11 03:14 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
To get the rear drum off do I remove the nut under the grease cap?
No,the drum should slide off over the studs w/the brakes released. You might have to bang on the drum face with a dead blow hammer to loosen up the drum from the hub,D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
