Re: Flexplate Bolt Removal?
[Re: bordin34]
#1039890
07/25/11 03:42 PM
07/25/11 03:42 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
put a 1 1/4 socket and breaker bar on the big bolt on the damper on the front of the engine to hold it from turning...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: bordin34]
#1039891
07/25/11 03:42 PM
07/25/11 03:42 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes you can use one of the holes in the flexplate and catch a ridge on the back of the block with a large screw driver or a small pipe, it takes another person too.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: bordin34]
#1039894
07/26/11 11:42 AM
07/26/11 11:42 AM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I simply get the bolt and wrench in the position with the least leverage for the engine to turn, yank the wrech, out it comes.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: MoparforLife]
#1039899
07/27/11 09:18 PM
07/27/11 09:18 PM
Posts: 15,487 Florida
scratchnfotraction
I have a long 12' double boxed end 6 point wrench I use like said,get it into position with least amount of leverage to turn the engine. have your buddy hold the crank bolt again also use 2 wrenches hooking the open end with the boxed end of the other to make it 14-15 inches for more leverage.
[Re: bordin34]
#1039901
07/27/11 11:27 PM
07/27/11 11:27 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Thanks, I cant get a socket on there without it coming off because the heads of the bolts are so short. I may try tomorrow with a breaker bar and very carefully try to apply torque without twisting off of the head.
That is exactly why I said to take the socket to the grinder and flatten the end so that it fits down on the head of the bolt square and not on the internal taper of the socket.
[Re: bordin34]
#1039903
07/28/11 09:10 PM
07/28/11 09:10 PM
MoparforLife
Upper Midwest
I took a grinder to the socket and that did it. The motor is now sitting on my garage floor.
Glad you got it.
[Re: MoparforLife]
#1039904
07/28/11 09:14 PM
07/28/11 09:14 PM
scratchnfotraction
Glad you got it.
x2
