Re: The losing streak continues.. [Re: weedlayer] #1038955
07/26/11 10:33 AM
07/26/11 10:33 AM
tboomer Offline OP
tboomer  Offline OP
you know you will have to drill the hole for the stem to put a tube in.
Ray...I can't use the excisting one?
Re: The losing streak continues.. [Re: weedlayer] #1038956
07/26/11 10:34 AM
07/26/11 10:34 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Who is he going to get to do that for him?
I didn't have to drill my draglites.
Ted, you did buy 2 tubes right???
Re: The losing streak continues.. [Re: JERICOGTX] #1038957
07/26/11 10:39 AM
07/26/11 10:39 AM
tboomer Offline OP
tboomer  Offline OP
Just one,Jeff...I can't run with just one??
Re: The losing streak continues.. [Re: tboomer] #1038958
07/26/11 10:40 AM
07/26/11 10:40 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
You should run them in both, as a tube stiffens up the sidewall.
Re: The losing streak continues.. [Re: JERICOGTX] #1038959
07/26/11 10:43 AM
07/26/11 10:43 AM
tboomer Offline OP
tboomer  Offline OP
Thanks...I just need to get by for this coming weekend..Woud that be ok before ordering another one?
Re: The losing streak continues.. [Re: tboomer] #1038960
07/26/11 11:11 AM
07/26/11 11:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hey man look at the bright side, you stuff 'aint broke and you got to go play.
Coming soon!!!!
Re: The losing streak continues.. [Re: tboomer] #1038961
07/26/11 12:06 PM
07/26/11 12:06 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
I had to drill my Pro Stars
never put tubes in my Draglites
