Resealing power steering box #1038886
07/24/11 10:34 AM
07/24/11 10:34 AM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
Where can I buy a seal kit for a steering box out of a 69 Plymouth B Body? Power steering big block car.
Thanks,
Re: Resealing power steering box [Re: Lugnutz] #1038887
07/25/11 07:01 AM
07/25/11 07:01 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
You could try to pour some brake fluid into the box (about one tea spoon). The brake fluid will let the seals swell up and might stop leaks. It's at least worth a try - worked for many guys having a leaking PS box.
Re: Resealing power steering box [Re: DGS] #1038888
07/25/11 10:28 AM
07/25/11 10:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
While worth while this is just a bandaid around the real problem, though if this is the road taken a power steering stop leak may be the better choice .
You really only have 2 seals , one on the either input and output shaft , I have changed the lower with the box still in the car , should be able to get them at a REAL parts store.
