68-70 Pop-out Quarter Glass Weather Strip #1038875
07/24/11 08:15 AM
07/24/11 08:15 AM
Jackson, Mississippi
CornDogsCharger Offline OP
Every 68-70 B Body I have messed with so far have all been hardtop cars, so I am not familiar with the post cars as much. Does anyone have a good "How-To" on replacing the weather strip around the pop-out glass on the post cars? Pages from a service manual would be great too if you have it. The car my friend is working on is a '68 Plymouth Road Runner. Thanks for you help!
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: 68-70 Pop-out Quarter Glass Weather Strip [Re: CornDogsCharger] #1038876
07/24/11 02:17 PM
07/24/11 02:17 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I just did mine this spring, it was pretty straight forward, I did not have to replace the weatherstrip in the hinge area tho.
The weather strip simply pushes on the frame of the window. Some WD 40 or PB blaster helps.
My only real task was closing up the gap between the quarter panel and the rubber gasket. I would up using some 3m strp chalk between the metal frame and the inside gasket edge to push it out.
