Re: hooking AC back up, what do I do?
[Re: kcmopar]
#1038838
07/24/11 05:54 AM
07/24/11 05:54 AM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The normal procedure is to use a manifold gauge set and hook the vacuum pump to the center hose...both the low side and high side valves are opened when pulling a vacuum.
If you're going to recharge it with a single hose can tapper, hook the vacuum pump to the low side fitting.
If the system has been completely flat for an extended period it would be a good idea to replace the receiver/dryer.
