Re: Cam advanced 30 degrees!
[Re: shoebox]
#1038724
07/24/11 05:40 PM
07/24/11 05:40 PM
Posts: 1,377 Ohio
Todd
Ohio
Thank You for your service
ditto! to all our servicemen on here
Thank You! After years of active and reserve duty I Have about a year left until retirement.
[Re: Devilbrad]
#1038725
07/24/11 05:50 PM
07/24/11 05:50 PM
Posts: 1,377 Ohio
Todd
Ohio
I had a similar problem on a bone stock 5.2 Magnum engine in my Dakota. Put a new Comp Cams timing set on it, never ran after that. Moved across country, played around with it for a while and finally decided to check cam center line. Same thing, dot was three teeth off on the cam gear. EFI engines luckily wont run like that, LOL
When I checked the marks on the gears there were no dots on the crank gear. So when it was assembled the keyway ended up being where the dot was. That ended up being 3 teeth off. Now looking back I should have degreed it then and found TDC. That put the crank keyway at about the 1 oclock position. This was my first big block. I guess I learned the hard way.
[Re: BB Dart 69]
#1038726
07/24/11 06:05 PM
07/24/11 06:05 PM
Posts: 831 Missouri
galen
Missouri
Same here, Nothing but respect for anyone in the military.
Re: Cam advanced 30 degrees! HP loss?
[Re: galen]
#1038727
07/24/11 08:38 PM
07/24/11 08:38 PM
Posts: 1,377 Ohio
Todd
Ohio
Thanks again!
I was wondering what the ET loss or even HP loss was with it off that far. If recall it went 8.20 in the 1/8. According to the moroso calulator it should be close to 6.50. Is it possible to gain that much?
[Re: Todd]
#1038730
07/25/11 02:35 PM
07/25/11 02:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks again!
Hell with it being that far off I'm suprized it even ran let along not breaking parts... I had a roller cam that the key way was off 27* and it crashed the pistons... I just lined up the dots to get a base line before starting to do the degreeing
