How to get rid of a musty smell inside a car #1038654
07/23/11 06:43 PM
07/23/11 06:43 PM
ND
Birdlover Offline OP
ND
I have a car (not my Roadrunner) that sat in damp garage with a dirt floor for a number of years. Any suggestions on how to get rid of the musty smell from the seats and carpet? I have been airing it out in a dry garage the last month but the smell is still strong. I can shampoo the interior but is there a product that specifically addresses old odors? Thanks!
1969 Road Runner, B7 Blue, 383, Auto
Re: How to get rid of a musty smell inside a car [Re: Birdlover] #1038655
07/23/11 07:34 PM
07/23/11 07:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Fabreze works pretty well to get rid of tobacco smoke etc. It might do what you need.
Re: How to get rid of a musty smell inside a car [Re: stumpy] #1038656
07/23/11 07:40 PM
07/23/11 07:40 PM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
bannas ive heard also i think baking soda to
Re: How to get rid of a musty smell inside a car [Re: mopwrd340] #1038657
07/23/11 08:47 PM
07/23/11 08:47 PM
Jackson, Mississippi
CornDogsCharger Offline
A used car dealer told me a trick he always did to remove the smoker's smell in a car.... it might also help in your situation. Take a paper plate and spread out un-used coffee grinds on it. Sit it on the floor in the middle of the interior. For strong odors, more than one plate of grinds might be required. Coffee grinds are a filter and they will soak up the smell. It will take some time but over a period of time, the smell will go away. At first the car will smell like a coffee shop (which isn't so bad). About once a week you will need to stir the grinds up a little. After a month you'll need to replace the grinds with fresh grinds.
I bought an '87 Ram Charger about 5 years ago and the guy I got it from smoked almost a pack a day. It was bad in there. I did the coffee grind trick and let the truck sit in the hot summer sun, and after a few months, it was all gone. Hope it works for you!
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: How to get rid of a musty smell inside a car [Re: CornDogsCharger] #1038658
07/23/11 09:02 PM
07/23/11 09:02 PM
IN
ahy Offline
ahy  Offline
IN
A shampoo would be a good idea. Add some disinfectant to the shampoo mix then let it bake in the dry garage.
Re: How to get rid of a musty smell inside a car [Re: Birdlover] #1038659
07/23/11 09:13 PM
07/23/11 09:13 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I'd be pulling the seats and carpet out and set them upside down in the sun, then have a look/see if there is anything obvious molded or mildewed that needed cleaning.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: How to get rid of a musty smell inside a car [Re: Birdlover] #1038660
07/23/11 11:28 PM
07/23/11 11:28 PM
NY NY
3
340duster340 Offline
NY NY
my jeep had a weather seal leak and the carpet got wet. so it started to smell musty. then it rained more and the leak got worse, so i put some news paper under the floor mat soak it up...then i forgot and now the car smelled like musty wet newspapers.
long story short i sprinkled some baking soda on the carpet and left the rest of the box wedged under the seat...smell is pretty much gone now.
Re: How to get rid of a musty smell inside a car [Re: 340duster340] #1038661
07/24/11 12:32 AM
07/24/11 12:32 AM
PA USA
ScatPakWarehouse Offline
Good Guy Alert
Good Guy Alert
PA USA
Try Simple-Green scrub interior /vac & let it dry in the sun ... Good Luck
Mopar Parts Hoarder ... Still Crazy after all these years.
Re: How to get rid of a musty smell inside a car [Re: ScatPakWarehouse] #1038662
07/24/11 12:47 AM
07/24/11 12:47 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Your best bet will be to take the car to a shop that has an Ozone machine. They put the box in the front seat, leave the car running and the blower on recirc. The ozone gets all through the duct work and works its way into the soft materials in the car. Ozon is a powerful oxidizer and will kill musty, smoke and most any other organic odor.
A shop in my area charged me $70 to do this and it worked. 2 full interiro shampoos and lots of fabreeze had failed, so the ozone was actually cheaper than the failed treatments!
Astrobuf
So, are you really a Rocket Scientist?
Re: How to get rid of a musty smell inside a car [Re: stumpy] #1038663
07/24/11 01:28 AM
07/24/11 01:28 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Pull to the side of the road and tell her to get out of the car
Re: How to get rid of a musty smell inside a car [Re: Birdlover] #1038664
07/24/11 07:22 AM
07/24/11 07:22 AM
places
79powerwagon Offline
places
Musty is mold. That needs to be killed and removed to eliminate the smell (as opposed to covering it up). Don't forget the insulating materials, too. It all has to come out, be dried/treated/replaced.
Re: How to get rid of a musty smell inside a car [Re: 79powerwagon] #1038665
07/24/11 10:50 AM
07/24/11 10:50 AM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Mold or mildew is almost certainly the cause of the smell. Many molds can cause health problems. Sometimes the health effects are small or minimal, other times the effects are more serious. Often the effects are difficult to trace back to the mold, so I wouldn't take any chances. Remove or kill the mold and mildew and the odor problem will also be gone.
Re: How to get rid of a musty smell inside a car [Re: QuickDodge] #1038666
07/24/11 12:13 PM
07/24/11 12:13 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
yep, full strip and clean.
Dryer sheets have been mentioned also, but I'd wash first.
Re: How to get rid of a musty smell inside a car [Re: Birdlover] #1038667
07/24/11 12:18 PM
07/24/11 12:18 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Well- I learned this trick from an old Hippy...
Take 3-4 incense cones (not the sticks- you want the cones) and light them. Place them in the ashtray(s)- your choice, and then shut all the windows and leave the car sit at least overnight- longer if possible.
The car will initially smell like whatever scent of incense you used. But after a day or two, that will dissipate, and there you have it.
I've done this on a couple of former smoker's cars.
I know Fabreeze works well on material- so might be a good shot.
I have a Dodge Stratus that sprung a leak in the trunk seal. Water filled the spare tire well with water- which then mildewed.
I scrubbed it all out with Simple Green- then put a bag of cat litter in the well, slit the bag on the top and left it in there for a week.
After I removed it the smell was gone. Had to replace the seal of course....
Hope this helps,
CC.
Re: How to get rid of a musty smell inside a car [Re: chargincharles] #1038668
07/24/11 01:45 PM
07/24/11 01:45 PM
Frozen Wastelands, Ontario, Ca...
Dr Lebaron Offline
Dr Lebaron  Offline
Fabreeze, Bounce dryer sheets [off brand doesn't cut it IMHO] Get some charcoal, place in paper bags and put some in the trunk/inside.
Re: How to get rid of a musty smell inside a car [Re: CornDogsCharger] #1038669
07/24/11 02:26 PM
07/24/11 02:26 PM
rockville va.
superbee68 Offline
superbee68  Offline
rockville va.
Re: How to get rid of a musty smell inside a car [Re: superbee68] #1038670
07/24/11 02:34 PM
07/24/11 02:34 PM
Kirkland, Washington
Pacnorthcuda Offline
Considering the cost of new carpet, and the relative ease of installation, I would at least consider its replacement. Think how nice new carpet would look too.
Headliners can also trap smells (especially tobacco) and are really cheap, but they are a pain to install.
Re: How to get rid of a musty smell inside a car [Re: Pacnorthcuda] #1038671
07/24/11 04:30 PM
07/24/11 04:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
ZorbX is a commercially and readily available odor remover but it won't kill mold or mildew.
To kill mold or mildew you'll need to use bleach or ammonia. Bleach will harm the colors in any fabric so I suggest ammonia. Either should be used in a well ventilated area.
The problem you're going to face is you'll only get it off the accessible surfaces. However, mold and mildew aren't that particular and will form on virtually EVERY surface. They particularly like heat and moisture so baking things in the hot sun is doing nothing more than drying the fabric and airing it out - it isn't killing the fungus.
Good luck.
Re: How to get rid of a musty smell inside a car [Re: Stanton] #1038672
07/24/11 06:16 PM
07/24/11 06:16 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
I can't believe nobody said---- LYSOL. It says it kills mold and mildew on contact right on the can. My garage is a bit damp, I blast the carpets/ under the dash and under the seats once in a while if the car dosen't come out. Seems to work. I go through a costco size can in a year. It's also important to keep air circulating. Most important to find the cause.
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: How to get rid of a musty smell inside a car [Re: WayneM] #1038673
07/24/11 06:53 PM
07/24/11 06:53 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
"Pull to the side of the road and tell her to get out of the car '
"MAKE HER WEAR UNDER WARE"
