Re: Original seat height position, E bodies.
[Re: yorker]
#1038477
07/23/11 03:05 PM
07/23/11 03:05 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
To me, after driving newer trans ams and other sporty cars that had the seats that sat low, I really don't notice nor does it bother me. Now if you go from a truck to an e-body, then it's very noticeable.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: yorker]
#1038481
07/23/11 05:32 PM
07/23/11 05:32 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
I find mine to be too high, and not slide back far enough. This puts the steering wheel too close for my liking. A bit of recline would be nice to have. If the back of the seat mounts could be lowered a half inch or so, I think it would be perfect. ![](/ubbthreads/images/graemlins/thumbs.gif) By the looks of it, the floor-pan will have to sectioned because the seat tracks are flat with the floor. ![](/ubbthreads/images/graemlins/frown.gif)
Mo' Farts
Moderated by "tbagger".
[Re: wally426ci]
#1038483
07/23/11 07:27 PM
07/23/11 07:27 PM
Posts: 175 Red Lion, PA USA
scamper340
Red Lion, PA USA
I felt the same way about my Scamp. The previous owner added '70 highback buckets and they always felt a little low compared to my '69 Swinger bench seat. When I redid the seats in the Scamp, the spacers were missing from under the seat rails. They make reproductions now so I installed them when I refinished the tracks. I also had new foam installed when I had the seats recovered. Between the foam and the spacers, it probably added a good 3 inches. It feels totally different sitting in it now, like a new car. I don't know if you can see much of a difference in the pics, but you can definitely feel it. Before: After:
[Re: MuuMuu101]
#1038485
07/23/11 08:41 PM
07/23/11 08:41 PM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
Are the spacers under the seat tracks? Most are broken and missing by now.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
[Re: Challenger 1]
#1038486
07/24/11 10:56 AM
07/24/11 10:56 AM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
That's why you old guys like B body's.
depends if the padding is worn flat also...but, you are correct that the steering wheel and seat position seems a little off.. it's worse when you have a bench seat...ask me how I know.... ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: ahy]
#1038488
07/24/11 11:50 AM
07/24/11 11:50 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I'm only 5'5" so I literally can't see a damn thing out of a typical e body ![](/ubbthreads/images/graemlins/laugh2.gif) . Very uncomfortable, but the looks are undeniable.... MB
[Re: HPMike]
#1038490
07/24/11 02:47 PM
07/24/11 02:47 PM
Posts: 2,554 Maryland
wally426ci
Maryland
I'm only 5'5" so I literally can't see a damn thing out of a typical e body . Very uncomfortable, but the looks are undeniable....
MB
Tha picture is bad ass.
[Re: 2Bad360sfromNC]
#1038492
07/24/11 11:45 PM
07/24/11 11:45 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I used the stock seat mounting spacers under the front only. It did help recline it a bit.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
#1038495
07/25/11 12:18 PM
07/25/11 12:18 PM
jbc426
West Coast, USA
Did E bodies have mounting spacers from the factory ????
I just see the tracks with the studs sticking out on mine. I guess I could shim the front studs with a few washers and see how big a difference that makes.
I picked up a couple sets from RT Specialties or Dale's 'Cuda Shop or somewhere.
My seats have new foam. I wish they sat a bit lower as my head is up close to the headliner, but with the spacers adding to the the recline, i'm used to it.
