Re: A-Body Small Block MPG's?
[Re: dennismopar73]
#1038285
07/23/11 12:23 AM
07/23/11 12:23 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
wow 30 mpg i want that one , best i ever got was 16 witha 360 and 21 with a 6 cyl so idono good luck
I believe the member was HotRodDave
[Re: topside]
#1038289
07/23/11 02:04 AM
07/23/11 02:04 AM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
I had a 70s 360 in my 67 Barracuda FB with an 833 o/d trans and 3.23s. I was getting 19 mpg mixed driving back and forth to work. I never did take it anywhere very far when I had the o/d, so no real highway numbers. I bet it would have done low 20s pretty easy. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: Jim_Lusk]
#1038293
07/23/11 03:29 AM
07/23/11 03:29 AM
phantomx
W. Sacto CA. USA
I think aerodynamics is where you are gonna find the big numbers. After you get the o/d trans, perfect tune, etc. Also, I think 3.23s and o/d is a great combo. Travis..
[Re: MuuMuu101]
#1038296
07/23/11 12:37 PM
07/23/11 12:37 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
What kind of mpg's can you expect from an auto SB A-body? The engine doesn't necessarily have to be built up. But something around stock. Is there any ways of improving it to get around high 20's on highway? Personally I drive about 60 mph on the freeway, but occasionally go 70 on longer trips. Very conservative driver. I know a member here had a 68 Barracuda trying to get 30 mpgs but he sold it for his new business.
318 2 barrel and 2.9ish gear driving the way you state should get you over the 20 mark, close to 25. Driven right they weren't all that bad for mileage and still had some steel around you. Not like the go karts they call cars now that should be getting a whole lot better in comparison and for what you pay.
[Re: HotRodDave]
#1038297
07/23/11 02:43 PM
07/23/11 02:43 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
https://board.moparts.org/ubbthreads/show...e=0#Post3944014
You can read about my last adventure there. Soon as I get caught up on some bills I will be doing another that will get over [Email]30mpg@70mph[/Email]
Hey HotRodDave. How many mpgs did you get with the Barracuda before you had to sell it?
[Re: MuuMuu101]
#1038298
07/24/11 11:23 AM
07/24/11 11:23 AM
Posts: 1,155 Cruising!
QuickDodge
Cruising!
The 1988 Chrysler 5th Ave was rated at 23 mpg highway by the EPA. These had the 318, lock up torque converters, and often had 2.2 or 2.45 axle ratios. The 5th avenue will probably be heavier than most A bodies.
The 5th avenues were NOT noted for performance! The high rear axle ratio was one of the primary reasons for their lackluster performance. An overdrive transmission will allow for the low RPM's needed for highway fuel economy, but the lower rear gears will allow for more acceptable performance.
If a person's primary interest is economy, a 2.76 with an overdrive could potentially yield better mpg's than a 3.23 gear in many situations. The 3.23 would definitely yield better performance and probably wouldn't hurt mileage to much. Of course this will depend on where and how the A-body in question is being driven. For example, in an area with lots of steep hills, a 2.76 gear may not allow an overdrive transmission to shift into overdrive very often. In this situation, a 3.23 with overdrive would obviously yield better mileage, assuming the transmission can shift into overdrive and have the necessary power to pull the hills. (and the 3.23 gear would hold the car back better on down hill grades)
[Re: QuickDodge]
#1038299
07/24/11 04:18 PM
07/24/11 04:18 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The best MPG I got under normal 70 mph hwy driving conditions was 29 mpg.
All the work I did to it yielded about 5mpg improvement over identicle driving conditions with the original 2bbl 318. It had a lot more power through out the RPM range too. It pretty much needed premium fuel but the cost was out weighed by the improvement, cost per mile was down significantly.
