Headers on a 66' Hemi Coronet #1037994
07/22/11 03:11 PM
07/22/11 03:11 PM
West Central Wisconsin
Exciter72 Offline OP
I was looking into putting a new TTI exhaust system on my Hemi Coronet. Are there any watch outs or concerns I should be aware of? Is it a big issue to eliminate the heat riser tubes to the back of the intake? I plan on driving the car a lot. I know I need to install a mini starter. Any advice would be appreciated.
Re: Headers on a 66' Hemi Coronet [Re: Exciter72] #1037995
07/22/11 03:54 PM
07/22/11 03:54 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Blocking the heat riser off isn't an issue.
If you live in a coolar climate the engine will
have to warm up after start up and especially if you have no choke.
logan426
