Re: DIY help for sagging seat?
[Re: Exit1965]
#1037749
07/21/11 10:52 PM
07/21/11 10:52 PM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
I would think you have a stretched out spring or two or possibly broke. Seems it would be a fairly easy fix if ya could find new donor springs. Probally wouldn't hurt to get some input from a upolstery shop
[Re: Exit1965]
#1037750
07/22/11 08:26 AM
07/22/11 08:26 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
What I did, kinda redneck I guess, was the following:
Disassemble seat. Remove vinyl, foam, burlap. Look at springs. Mine were in tact, just old. I welded rods across the springs to make them move as a unit. Think of taking some coat hangers and tacking them to the springs. That's what I did. Raised the seat a bit, but firmed it up nicely.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: Exit1965]
#1037752
07/22/11 09:14 AM
07/22/11 09:14 AM
70Coronet500Vert
St Charles MO
I think I reused the old foam on that one. However, when I can, I buy new foam. And yes, cutting up the green foam from a fabric store will help. The green foam is more dense. It is expensive. But then, so is this hobby! You can strategically place green foam under the factory foam for lateral support for your rear end too.
I would buy new burlap, that will help contain the crumblings from the old foam. I always use new burlap, and the thin cotton material when I can.
[Re: Exit1965]
#1037754
07/28/11 12:20 AM
07/28/11 12:20 AM
Posts: 923 Missouri
convertriple
super gas
super gas
Missouri
Two things I did that firmed mine up alot: Go to Menards/Lowes/Home Depot and buy carpet samples. The stiffer the backing the better. They are usually about 1.5' by 2.5'. I paid 4 bucks for two. Take your seat out, flip it over so you are looking at the springs, work the carpet samples under the springs between the springs and the foam. This keeps the springs from going into the foam. If you are willing to take off your seat covers: I bought 1/2 or 3/4 inch thick high-density foam (green, if it matters) and used spray trim adhesive to glue this onto the top of the foam where you would be sitting. It was interesting trying to get the covers back on, they were very tight. So there you have it, a couple of low buck ways to stiffen up your seats, these worked great for me....good luck.
