belt squeel #1037661
07/21/11 06:40 PM
07/21/11 06:40 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok, I've about pulled my hair out with this.
1970 Hemi cuda with Vintage air system. Single belt pulley, the belt wraps around the alt, lower crank and the a/c compressor only
changed the pulley on the power master alt to an original mopar pulley with no help, changed the belt , still no help and I have it about as tight as I'm comfortable getting it.
and I still have a belt squeel on accel, and all this is WITHOUT the a/c compressor engaged. It's just free wheeling
Pulley alignment is dead on btw
Re: belt squeel [Re: gtx6970] #1037662
07/21/11 06:58 PM
07/21/11 06:58 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Did you try any belt dressing spray ?
Re: belt squeel [Re: gtx6970] #1037663
07/21/11 07:56 PM
07/21/11 07:56 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
is your battery overcharging
Re: belt squeel [Re: gtx6970] #1037664
07/21/11 07:57 PM
07/21/11 07:57 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
How old are the pulley's on the crank and alt?
I just went through this on my 318 Challenger. Turned out the water pump pulley had glazed! Sandblasted and painted it and the noise has gone (along with a new belt!). Spent a lot of money before I finally figured it out!
1971 Challenger
Re: belt squeel [Re: can.al] #1037665
07/21/11 09:41 PM
07/21/11 09:41 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
No , charging system seems normal
Pulleys are all new, ( repops from bouchillon)and are powdercoated right out of the box.
It has one of the power master alternators on it and the pulley was to narrow for a factory belt.
BTW , I had this problem with the alternator with it's aftermkt pulley .
So I pulled the alt off and replaced the pulley with an original from a used original alt I had laying around, Another new belt was put on at this time in case the 1st one was glazed.
pulley alignment is dead on best I can tell. The a/c is not charged and the compressor does not engage so the compressor clutch pulley is just free wheeling and I can spin said pulley by hand with no belt on it. So I don't think it's causing any parasisic drag on the belt, same thing on the alternator pulley.
The compressor mounts very similar to an original B/RB location and the spacing between the alternator and compressor are very close to OE stock.
I'm baffled, as there is no way 2 belts can be installed like an OE setup.( lower crank pulley is not capable of it )
Re: belt squeel [Re: gtx6970] #1037666
07/21/11 09:56 PM
07/21/11 09:56 PM
Florida STAYcation
Florida STAYcation
POWDERcoated in the V-slot ? ... tooooo slick ...IMO.
Re: belt squeel [Re: dOc !] #1037667
07/21/11 10:24 PM
07/21/11 10:24 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I had thought about that, but the pulleys are done in a flat black and are not superslick like gloss back would be ,,,,,so I dont't ''''''think''''' that is it
Re: belt squeel [Re: gtx6970] #1037668
07/21/11 10:27 PM
07/21/11 10:27 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
This is the set up btw
Alternator pulley has been changed since these pictures were taken.
Re: belt squeel [Re: gtx6970] #1037669
07/21/11 10:27 PM
07/21/11 10:27 PM
Florida STAYcation
Florida STAYcation
I will BET if you ruffed-up those slots with some sandpaper .. then prob would go-away.
Re: belt squeel [Re: gtx6970] #1037670
07/21/11 10:29 PM
07/21/11 10:29 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
another view
Re: belt squeel [Re: dOc !] #1037671
07/21/11 10:40 PM
07/21/11 10:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
......Bill I'd have to agree with the DoCToR, as I've had the same problems of squeal with pulleys that were chromed plated,...the powder coating is probally too resistant to abrasion from the belt, so the belt can't bite, no matter how tight you tension it,....the AC pulleys, are they clear powder coated as well?.....try belt dressing first, if the squeal goes away,...sand/abrade the pulley grooves, new belt
Mike
Re: belt squeel [Re: gtx6970] #1037672
07/21/11 10:50 PM
07/21/11 10:50 PM
IN
ahy Offline
ahy  Offline
IN
I'd go ahead and get a 4 groove crank pulley and run two belts. The basic setup is designed for it and you will have a lot more load when the AC gets going. I have the same basic setup with Bouchillon mounts and the AC/alternator belt has been trouble free with two belts.
Re: belt squeel [Re: ahy] #1037673
07/21/11 10:59 PM
07/21/11 10:59 PM
Florida STAYcation
Florida STAYcation
...on a side-note ...
I am going to try and put a serp-belt system on any new builds. That is a slick system ...with the built-in tensioners.
Re: belt squeel [Re: dOc !] #1037674
07/22/11 09:09 AM
07/22/11 09:09 AM
Oklahoma
LXIXcharger Offline
LXIXcharger  Offline
Oklahoma
Had the same problem for awhile, turned out to be the power steering pump pulley. Tightened the belt and all is good.
Re: belt squeel [Re: LXIXcharger] #1037675
07/22/11 04:25 PM
07/22/11 04:25 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This may not apply but when we had 'chirping' belts, we'd always put just a bit of door ease stick lubricant on the sides and the noise went away.
Re: belt squeel [Re: gtx6970] #1037676
07/22/11 07:26 PM
07/22/11 07:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Bill,
I have just about the same set up,4 groove bottom pully and no problems.
Re: belt squeel [Re: 62maxwgn] #1037677
07/23/11 10:49 AM
07/23/11 10:49 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I would like to run a 2 groove belt setup on the a/c ,BUT,
The pulley arrangement and pulley depth will not allow it.
It has the 4 groove lower pulley and starting at groove closest to the balancer going forward.
Stock thick hemi balancer
the rear most slot is empty( nothing lines up with it)
2nd one runs the a/c and alternator belt.
3rd one runs the power steering ( and is slighty smaller in OD versus the 2 rear most grooves of the pulley )
4th ( and the most forward one - is empty- nothing lines up with it either)
power steering pump location prohibites running 2 belts on the a/c system. Short of making special brackets and spacers to essentially move the power steeering pump forward to use a different lower pulley groove. Then I have the problem of the smaller OD of the pulley to deal with.
going to try the sand the pulleys trick this weekend
Re: belt squeel [Re: gtx6970] #1037678
07/23/11 05:16 PM
07/23/11 05:16 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Bill,
I have since changed the pump since that picture,now running same pump as you show.On the 4 groove crank pulley,from front to back,power steering pump and water pump,middle two alternator and compressor,back is empty.I also have the 2 groove Bouchillon water pump pulley,everything lines up perfectly.It may be the thickness of the damper that is throwing things off.Your second picture looks exactly like what I have now.
Re: belt squeel [Re: 62maxwgn] #1037679
07/25/11 10:55 AM
07/25/11 10:55 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Bill,
The 440/383 uses a different bracket set up than hemi and you can run 2 belts on that set up compressor with no issues. I'll explain what I have been through on a hemi.
Guys this is long winded but it's the only way I can tell the masses of people on moparts what I did with mine.
My goal was to make the compressor appear as though it belonged and did'nt look out of place when looking at the engine. My set up is the same as Bill's so I it would fit up under the shaker base on my cuda convertible. I milled off all the unused mounting lugs off the compressor and shaped the lug areas to appear like part of the main case, then I removed the twin pulley and blackened it and the attaching hardware. Next I glass beaded the aluminum case and sprayed it semi-gloss black and re-install the twin pulley. I also blackened at the bracket hardware. I used a 4 groove big block pulley with a thin B/RB damper. With this pulley you will also use the 2nd and 3rd pulley for driving belts. For the sake of a cleaner look I chucked up the 4 groove pulley and cut off the 1st pulley nearest to the radiator, this really improves the appearance up front. Next I wanted to retain the correct appearance of using a federal pump on the my hemi their again wanting to make it appear factory. The standard hemi federal pump pulley cannot be used with a thin damper due to the incorrect off set that would cause belt mis-alignment. So I used a small block saginaw (no spoke) pulley which is close to the same diameter of the hemi federal pulley OD. After mounting the crank pulley and steering pump to the engine, I then used a grade 8 bolt to draw or press the steering pump pulley on the spindle and stopping when I had correct alignment on the front crank pulley groove (originally was the 2nd groove). After achieving the correct belt alignment I used loctite to secure the bolt to the pump spindle for the pulley. Now on the alternator I used the correct 2 groove hemi style pulley, again staying with the factory appearance. Water pump pulley is a 2 groove late 70's big block truck only pulley and Bouchillon sells it, it has a different off set then other 2 groove pulleys and is a one of a kind. I as well want to use both pulleys on the compressor for correct appearance and was told by Randy at Bouchillon that the compressor has very low drag and 1 belt is all it needs to turn it. I want 2nd belts, and that's why I did my pulleys the way I did but this is what I ran into. 1 belt on front groove of the alternator then to the 2nd groove on the compressor and then down to the 2nd groove on the crank pulley (was originally 3rd groove) that part was good also because I was able to put the belt on the outer groove of the alternator just like original hemi appearance. Now we go to the 2 belt. 1st groove of compressor then 2nd groove of water pump and then to the 1st groove of the crank pulley was (originally 2nd groove) and then over to the power steering pulley. Now I think I've achieved the best possible look after hours of jigging up etc, etc, etc and it's going to work right (wrong).. It all looks really good except for one major issue, when you start the engine the belt doesn't have enough surface area contact on the water pump pulley causing it it squeel, I tried belt dressing it doesn't work their is just to much drag on the pump trying to circulate the coolant. I had to remove the belt and go to the shorter belt to run the water pump because it allowed more belt surface contact area. It bites but that's the way it is. I need a larger OD water pump pulley that's not made currently with the correct off set and a smaller OD crank pulley that's not made currently so I get more belt surface area contact on water pump pulley to turn the pump with out creating belt squeel. Bill, unless you go to a funky idler system you cannot do both belts on the compressor or with out different water pump and crank pulley OD's.
Something I failed or forgot to mention is the mods I had done to the condenser for a cleaner appearance under the hood. When I had the condenser made, I had them put both INLET and OUTLET on the passenger top corner of the condenser. Why?? because you can now run both inlet and out lines off one side and eliminate the driver side line for a cleaner appearance.
Now stainless lines can be made to go across the core support on one side, and also a custom stainless line can be made to go right by the distributor (tight clearance) to the pump. Rick Tyre Blown71X moparts member did a superb, excellent,great job manufacturing and running my lines.
logan426
Re: belt squeel [Re: gtx6970] #1037680
07/27/11 02:55 PM
07/27/11 02:55 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Bill,
I forgot to mention that's a nice shot of the crapper in the back ground.
logan426
