Page 5 of 5 1 2 3 4 5
Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT??? [Re: Labratt] #1037451
07/26/11 10:13 PM
07/26/11 10:13 PM
Shelby mi.
JAKE68 Online content
JAKE68  Online Content
Shelby mi.
Gary..you've convinced me to stay with the 02/03's! If the front mounting bolt is dropped from the top mounting hole,to the lower one...what will that do? Lower the rear-end?...hit harder? If it does lower the body,the tire clearance on the street tires will be REAL CLOSE! That's going to be a BIG consideration..even though I'd like to level the car out! Thanks for the info,fella's!
Putting it in the lower hole raises the car by about .5. It softens the hit to the tire which is better for a so so track condition. The top hole is better suited for hard hooking track.Jake
JAKES AUTOMOTIVE
Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT??? [Re: JAKE68] #1037452
07/26/11 10:24 PM
07/26/11 10:24 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Gary! Guess it'll stay in the top hole...don't need it any higher! I use the 9-way Rancho rear shock...has anyone had a problem with them not having enough travel...and bottoming out?
Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT??? [Re: JAKE68] #1037453
07/26/11 10:43 PM
07/26/11 10:43 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
[quote) We have tried the 3400 and 3600 and 3800 springs...and none will out 60' the 002/003s! That is the best scienced-out mopar spring... in my opinion.
Jake..same thing Dick Landy told me at Carlisle...just before I ALMOST bought a heavier set!
Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT??? [Re: Labratt] #1037454
07/27/11 05:28 AM
07/27/11 05:28 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Be sure to check them as their are couple of different shocks, extended length should be around 25 to 25 1/2" long, if not the shocks may top out when you launch the car
Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT??? [Re: formula S] #1037455
07/29/11 06:28 PM
07/29/11 06:28 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Steve..just checked the advertised extended length on my Rancho RS 999114 9-Ways...it lists 24.250" as the extended length! Isn't that too short? You stated they need to be 25-25.5" long.Looks like my shocks might be a CULPRIT...as well as the shackle angle! What's the consensus on this???? Thanks in advance,guys!
Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT??? [Re: Labratt] #1037456
07/29/11 07:30 PM
07/29/11 07:30 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Randy,
You need to disconnect the rear shocks from the axle/bottom end and support the car from the frame, letting the rear suspension hang free/unloaded. then extend you shocks.... they should extend at least an inch or so beyond the mounting point.
Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT??? [Re: Mr340] #1037457
07/29/11 07:39 PM
07/29/11 07:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy,
First he needs to correct the shackle issue... the
spring will travel farther when corrected and the axle
will drop farther THEN he needs to measure the shock
