Cable shift trans speedo cable retainer #1036906
07/20/11 11:55 PM
07/20/11 11:55 PM
Chicago
curbman68 Offline OP
Chicago
I seem to have lost the retainer for the speedo cable were it enters the trans. Anyone have a picture of one so I know what I'm looking for? I know what the retainer fork for the later style trans looks like, is the earlier version similar, just smaller?
Re: Cable shift trans speedo cable retainer [Re: curbman68] #1036907
07/21/11 09:12 AM
07/21/11 09:12 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Cable shift trans speedo cable retainer [Re: 64dodge572] #1036908
07/21/11 09:33 AM
07/21/11 09:33 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yep he's got the right one there, You could make one easy out of some flat stock. I could take this one out if you need some measurements.
I have mechanical Aptitude.
I can screw up anything.
Re: Cable shift trans speedo cable retainer [Re: bboogieart] #1036909
07/21/11 02:01 PM
07/21/11 02:01 PM
Chicago
Chicago
Thanks guys, I have seen that thing around the garage about 100 times and didn't think it was the right one. Seems kind of crude compared to the later trans version.
Re: Cable shift trans speedo cable retainer [Re: curbman68] #1036910
07/21/11 02:09 PM
07/21/11 02:09 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
right? just flat stock with a semi circle in the end of it. Does the job though huh?
