MINI STARTER ??????? #1036777
07/20/11 09:19 PM
07/20/11 09:19 PM
Lehigh Acres, Florida
rickstershemi Offline OP
Okay....picked up a mini-starter today (91 Dak S/B).....question is the top starter bolt hole is way larger than the bottom hole, but the threads are the same.....does the top hole require a special bolt or a cam type spacer for aligning the starter....?????
This is for my 408/360 based stroker with a 70's a-body aluminum 4-speed 10.5" bell/h.
any help would be appreciated.....thanks in advance
Or did I just get the wrong mini starter for this application...????
Rickster
Re: MINI STARTER ??????? [Re: rickstershemi] #1036778
07/20/11 09:21 PM
07/20/11 09:21 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
your supposed to center the starter,thats why the hole is bigger on the top.
Re: MINI STARTER ??????? [Re: ro23car] #1036779
07/20/11 09:26 PM
07/20/11 09:26 PM
So if I get this right you just let the starter slide into the register in the b/h and use a bolt w/large washer to lock it in place....??????
Rickster
Re: MINI STARTER ??????? [Re: rickstershemi] #1036780
07/20/11 09:29 PM
07/20/11 09:29 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
thats what i did on my starter...
Re: MINI STARTER ??????? [Re: earthmover] #1036781
07/20/11 10:13 PM
07/20/11 10:13 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I just put a new starter on the Dart. Im using a 727.
But the top whole slides onto tranny, and a nut goes on it.
The rest of the wholes take the bolts.
Re: MINI STARTER ??????? [Re: rickstershemi] #1036782
07/20/11 10:23 PM
07/20/11 10:23 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I think if you check the top bolt hole is larger I have seen this due to the stud size in the trans case.
the correct position comes from the starter itself fitting into the case or adapter plate
home of the
Sox and Martin Hemi Duster
Re: MINI STARTER ??????? [Re: HEMIFRED] #1036783
07/20/11 10:55 PM
07/20/11 10:55 PM
The top hole on this bell is the same thread size as the bottom...????? But the top hole in the starter is twice the size of the bottom hole.....only two bolt holes to use.....with the starter in place and the bottom bolt installed it is very rigid.....?????
Rickster
Re: MINI STARTER ??????? [Re: rickstershemi] #1036784
07/20/11 11:31 PM
07/20/11 11:31 PM
Delray beach, Florida
P
Performance Only Offline
P
Rickster
if you have the nose of the starter located in the bellhousing, all you need to do is bolt it up tight. the shank of the stud that's normally used for the top hole is larger than the threaded area of a standard bolt. once it's bolted up it can't move around though so it's no big deal.
machine shop owner and engine builder
Re: MINI STARTER ??????? [Re: Performance Only] #1036785
07/21/11 08:49 AM
07/21/11 08:49 AM
Thanks guys....I'm going to make a bushing for the top hole to fill it up....don't like the idea of just slamming a bolt in there....probably would be fine....but no big deal to make a bushing either
Rickster
Re: MINI STARTER ??????? [Re: rickstershemi] #1036786
07/21/11 09:12 AM
07/21/11 09:12 AM
Arizona
Chris'sBarracuda Offline
Arizona
Rick..
Have been using it that way for years and years.
Because of using a P/G, adapters, and flexplates, larger hole
allows adjustment, to help ring gear/starter gear mesh.
15:1 540" B1... Same big upper hole w/ smaller bolt..
Chris..
Re: MINI STARTER ??????? [Re: rickstershemi] #1036787
07/21/11 09:33 AM
07/21/11 09:33 AM
Get-X Offline
Get-X  Offline
Rickster
If you have a production bell just use the correct stud. No need to fab any bushings.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: MINI STARTER ??????? [Re: Get-X] #1036788
07/21/11 09:41 AM
07/21/11 09:41 AM
s e mich
ro23car Offline
ro23car  Offline
s e mich
Rickster
hey mark shouldnt you be working lol. are you going to martin,ill be there on fri.and that hole is bigger so you can adj the starter so the gears can mesh properly.
Re: MINI STARTER ??????? [Re: Get-X] #1036789
07/21/11 09:42 AM
07/21/11 09:42 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I just have a bolt in mine and has been working good! I would never run A big one again.
67' charger 499 RB 10.57 at 127
Re: MINI STARTER ??????? [Re: Get-X] #1036790
07/21/11 09:42 AM
07/21/11 09:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Rickster
Yep... its just a shouldered stud... screws into the
trans and uses a nut.... bolt on the bottom hole
Re: MINI STARTER ??????? [Re: ro23car] #1036791
07/21/11 09:49 AM
07/21/11 09:49 AM
Get-X Offline
Get-X  Offline
Rickster
You should be working too!!! If I get home in time I may go to spectate. I'm too fat and old to race when it's this hot and am without a trailor atm. I could drive the GTX there, but I don't like to race without having a way to get it home if it breaks.
'65 Belvedere
'68 GTX
'57 Dodge pickup
