69 road runner dash lights #1036619
07/20/11 03:21 PM
07/20/11 03:21 PM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
I have no dash lights or radio light so i jiggled wires, played with the dimmer and headlight switch, then checked fuse box which I put in new fuses only to find out I have no power leading to the fuse. Any ideas? Thanks for any advise!
Re: 69 road runner dash lights [Re: indytex96] #1036620
07/20/11 04:17 PM
07/20/11 04:17 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Check the bulk head connection where it plugs in from the engine bay, jiggle it and if you get power you need to take it apart and clean it.
Good Luck
Re: 69 road runner dash lights [Re: indytex96] #1036621
07/21/11 12:31 AM
07/21/11 12:31 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Did you jump the dimmer?
I want my fair share
Re: 69 road runner dash lights [Re: indytex96] #1036622
07/22/11 11:06 AM
07/22/11 11:06 AM
pa.
dan9 Offline
dan9  Offline
pa.
If i remember correctly the dash light circuit gets its power from a tan wire going from the headlight switch to the fuse box then to the dimmer. It makes sense once you see it. As suggested i would jump that tan wire and see if i had lights. Maybe it is just a corroded headlight switch.
Re: 69 road runner dash lights [Re: indytex96] #1036623
07/22/11 02:47 PM
07/22/11 02:47 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
You possibly have no tail lights either.
logan426
